why is this fecked?
Old Sep 15, 2012 | 04:21 PM
LukeDaisley's Avatar
LukeDaisley
Default why is this fecked?
It's a injector clamp on a 1.7 cdti
On the other clamps there is 3-4 mm clearance. This one as you can see has been rubbing.
Has anyone had this before?
Old Sep 15, 2012 | 04:22 PM
LukeDaisley
Just to add all the valve clearanceys are within tolerance.
Old Sep 15, 2012 | 05:13 PM
Chaz888's Avatar
Chaz888
missing spacer or seal on the injector ,how dose it sit compaired to the others ?
Old Sep 15, 2012 | 05:19 PM
LukeDaisley
iv worked it out now. the monkey mechanic that had a go at it. by the looks of it fitted the injector without the top hat that the clamp sits on. and started it up, realised his mistake refitted it.
Old Sep 15, 2012 | 05:29 PM
Chaz888's Avatar
Chaz888
And this is why I work on on my own car ! how could he have missed that !
Old Sep 15, 2012 | 05:40 PM
LukeDaisley
its new to me I bought it today with a knocking noise form the top end. started taking it apart and found this. I am wondering how far the bodging goes.
Old Sep 22, 2012 | 11:50 AM
LukeDaisley
After some more investigation I found this.
Smashed piston
Due to using too much sealant to glue the sump.
The exsses broke off and got stuck in the oil pick up.
Some people amaze me with how far they take bridging stuff.
Old Sep 27, 2012 | 02:55 PM
black_jack's Avatar
black_jack
Black Jack
Ouch! - does that mean the 1st fault was due to it running dry of oil too?
Old Sep 27, 2012 | 04:30 PM
LukeDaisley
the first fault was due to some dumb ass fitting the injector clamp without the little top hat.
there doesn't seem to be any sign of it running too low on oil. ie shells are fine although im changing them for good measure. cam shafts are fine, no blueing and there well within wear limits, (at last I got to use my micrometer in anger). no play in the mains or the small ends either. just the rings and pistons.
luckily iv got away with just honing the bores.
verdict
Ł280 new set of pistons with rings.
Ł35 new shells
Ł51 head gasket set
new oil filter, oil, anti freeze
fitting this weekend.
Old Sep 28, 2012 | 03:56 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Replace the injector sleeve seals whilst its apart, they are a common problem on those
Old Sep 28, 2012 | 09:27 PM
LukeDaisley
Yeah that come as part of the head gasket set
Jim Galbally
59
Mar 21, 2005 06:54 PM
apples24
16
Nov 30, 2004 08:37 PM
Kev.H
18
Oct 14, 2004 09:30 PM
Nath
Aug 26, 2004 09:17 PM
Nath
12
Aug 6, 2004 12:05 PM
