thoughts on this please
Old Sep 13, 2012 | 08:38 PM
weeman84's Avatar
weeman84
Default thoughts on this please
hi basically i have a mk1 fiesta with a zetec turbo lump in. I need to get it on the road asap
Thing is the manifold i have on it at the mo is a modded over the gearbox type manifold. It loks a bit ropey and its been cut and shut. Im really not keen to use it. Thing is i need to keep the turbo over the box due to space and the size of the turbo. If i was to buy the manifold in the link, then make a pipe that bolts to the t3 flange and runs towards the gearbox so basically it keeps the turbo over the box would this still work well?
seen peopledo it to moody standard mild steel manifold but not stainless ones. i would also make some brakets that bolt to the gearbox to support the weight..... whats peoples opinions on this ?? would the manifold be any good??
thanks
http://www.ebay.co.uk/itm/Ford-Focus...item5895ad9eb3
Old Sep 13, 2012 | 09:45 PM
nevsrevs's Avatar
nevsrevs
I think not! I would put the money into a new over the box mani. Speak to Gary crazy cage of here, he might be able to sort you out.
I did try to mod one of those obx mani,s and it ended a costly operation.
Old Sep 13, 2012 | 09:53 PM
weeman84's Avatar
weeman84
but why wouldnt it work my way? Im not having to mod the manifold at all.....just make a pipe from this to the turbo?
Old Sep 13, 2012 | 10:01 PM
nevsrevs's Avatar
nevsrevs
It would work, just not very well as collector would be so far away from turbo, could you not get 1 of the over the g box manis of the bay?
Old Sep 14, 2012 | 12:54 PM
Neil.'s Avatar
Neil.
Any pictures of the engine bay and the spec? Can you use a Mk1 FRS manifold? Seen it done, worked well and was cheap enough too.
Old Sep 14, 2012 | 07:07 PM
weeman84's Avatar
weeman84
standard focus rs one wouldnt be good enough for me......
surely the manifold collector distance wouldnt be that much further?
my spec is
steel rods
forged pistons
uprated head gasket
uprated valve springs
turbo development hybrid t34/t28 turbo
Old Sep 14, 2012 | 07:13 PM
weeman84's Avatar
weeman84
and this is what it looks like now. Flow would be crap, looks crap. Apparently this was one of the first area six manifolds. Had it a very long time. Ive seen someone selling similar looking ones on ebay for about £250 but they look a bit crap. seen upclose pics and the work isnt that good
thats why i thought of the idea of the manifold at the begining of the thread and running a remote pipe over the to the gearbox for the turbo.....
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fezman1
Oct 2, 2015 01:22 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
gingeRS
17
Oct 2, 2015 09:42 AM
