Lacquer "crazing" or "clouding" - fix?
Old Sep 11, 2012 | 03:15 PM
Thrush's Avatar
Thrush
Irritating c........
Default Lacquer "crazing" or "clouding" - fix?
For the most part, my paint is pretty good - it's generally smooth and apart from a few light scratches (mainly bush rash) it's tidy. On the drivers side leading edge of the door and bottom of the A-Post though, there appears to be an effect in the lacquer, like a crazing or clouding. It almost looks like overspray, but I'm not sure it is. It's just as smooth as the rest of the paint, and I'm thinking it's the lacquer itself
Is it likely this can be buffed/polished out? Or does it need wet and dry rub down and then re-buff?
Old Sep 11, 2012 | 07:38 PM
iansoutham's Avatar
iansoutham
OCD Victim
The lacquer finish is breaking down, probably due to poor quality prep or UV protection.
I would say that respray is the only option there. If you try to machine it out, it will only get worse.
Old Sep 11, 2012 | 07:41 PM
botters's Avatar
botters
competant bodger
respray unfortunatly as it would appear that has been painted before, badly and probably with single pack laquer which is shite!
Old Sep 11, 2012 | 07:43 PM
Ryoishikawa's Avatar
Ryoishikawa
Very similar to lacquer peeling . Repaint is the only thing
Old Sep 11, 2012 | 10:19 PM
Thrush's Avatar
Thrush
Arse
Old Sep 12, 2012 | 07:58 AM
vaughant's Avatar
vaughant
Won't harm to try wet n dry 1500 paper first and then buff with g3?if that doesn't work you'll need to spray but it won't make it any worse and you've nothing to lose.
Old Sep 12, 2012 | 09:54 AM
Thrush's Avatar
Thrush
Me + wet n dry = a lot to lose
Russ Payne
Sep 25, 2015 08:29 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
Cos500
Sep 16, 2015 09:50 PM
nikki.n.tom
Sep 15, 2015 08:20 PM
rog
Sep 4, 2015 07:24 AM
