help needed please
Old Sep 6, 2012 | 07:33 PM
rsturbo27's Avatar
rsturbo27
Default help needed please
right i've changed lower arms on my frst also track rod arms car has had new lower suspension, problem i have now is the ball joint on lower arm, has started to rub on the inside of the disc (it is right lower arm) my question is looking at the wheel head on it looks as though is on a angle pointing in wards, can you adjust the camber or rod ends to pull the wheel straight, and of the disc, would a lazer allinement solve this problem as rubbing bad when driveing cheers
Old Sep 8, 2012 | 10:10 AM
rsturbo27's Avatar
rsturbo27
Any 1 shed any light on this can't drive the fuking thing really on verge of giving up on this car
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
