any mechinics on here.. knocking noise when you turn steering wheel?
just a question for the mechanics on here.
im trying to repair my other halfs car x5. has a problem theres a knocking noise when your turn wheel seems to be comming from both sides.
had a look underneath and the sound seems to be comming from the steering rack inner tie rod area i got someone to turn wheel and if i place my finger on the rack i can feel a vibration on the steering rack when you hear the knocking noise.
heres a short video i took in the dark with the inner tie rod boot removed. my friend is turning the wheel side to side & you can hear the noise.
http://www.youtube.com/watch?feature...&v=GAmPQVelb0k
anyone help or have any ideas what it might be.
heres a video i took today which you can see better in video as was in daylight.
you can see the tie rod is removed but still have noise as seen in video.
http://www.youtube.com/watch?v=tl9fX...ature=youtu.be
i heard some steering racks you can adjust them by a screw but not sure if its possible on the x5 rack.
anyone come across this problem before?
JoeyBoyden
Jan 4, 2024 02:36 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
