st170 high idle when cold
Old Aug 31, 2012 | 01:23 PM
LeeBee's Avatar
LeeBee
Default st170 high idle when cold
As title, is this common? And is there a fix? Its not a major problem, but i would just rather it didn't do it.
Thanks
Old Sep 8, 2012 | 06:20 AM
jonty's Avatar
jonty
all the same bud mines just like that
Old Sep 8, 2012 | 07:55 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
From memory when I worked at ford there was an issue with the st170 brakes from cold. Ie the servo was crap & they issued a recall that altered the cold start map to increase the revs by 2 or 3 hundred rpm for a short period of time to help the servo build up pressure quicker.
Old Sep 8, 2012 | 08:28 AM
LeeBee's Avatar
LeeBee
Ah, well that's ok then. Cheers guys.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
A.t.p
Oct 23, 2015 07:54 PM
