What do I need to fix on my car to get it to quit not starting.
Old Aug 28, 2012 | 10:26 AM
Brendan's Avatar
Brendan
struggling with reality
sounds like the immobilizer is not un-arming therefore the car is still being immobilized! I would think it caused when it happens by a bad connection! - These can be a complete pain in the rear end to get fixed, even by a good auto electrician as sometimes the fault is not there so you can not find it to fix it! I am dealing with a prob like this on my toy at the moment too!!!
Old Aug 28, 2012 | 10:29 AM
slammedorion's Avatar
slammedorion
I had a starter motor do the above.
Sometimes it was fine, other times nothing.
I replaced it in the end and all was fine.
Worth checking all your connections, earths etc.
Old Aug 28, 2012 | 10:41 AM
Steve Escos's Avatar
Steve Escos
Check the ignition switch as well. Common for the wire connections to fail.
Fordmad!
Sep 26, 2015 05:24 PM
rdvil
Aug 15, 2015 12:11 PM
yawiejon
15
Aug 9, 2015 06:36 PM
