finishing off zetec turbo conversion
Old Aug 27, 2012 | 05:06 PM
TomPengelly's Avatar
TomPengelly
Kapow!!
Default finishing off zetec turbo conversion
my series 2 is almost finished now. where the old triangular breather used to be on the front of the block, i need to block off somehow. Does anyone know the best way to do this?
Also, i want to make my oil return pipe fom my turbo to go where the flywheel timing bolt goes? Anyone know if thers someone that sells a threaded outlet pipe for this??
Old Aug 27, 2012 | 05:36 PM
slammedorion's Avatar
slammedorion
Blanking plate
http://www.burtonpower.com/zvh-breat...late-zvh2.html
Oil return wants going into the sump.
Old Aug 27, 2012 | 05:54 PM
TomPengelly
Kapow!!
Ah excellent! cheers for that!
Ok, just as high up in the sump as possible i take it? spose the best way is to take the sump off and drill a hole and tap it for a union to thread into it? on the bottom of my turbo i have a tapered bit for a hose to be clamped onto. il try and get the same sort of thing to screw into the sump.
Sorry for being a bit simple, ive never done anything like this before!
Thanks!
Old Aug 27, 2012 | 07:49 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i used a core plug on mine.
then took it out and had a breather fitting made lol
and yes, turbo return to sump
Old Aug 27, 2012 | 07:57 PM
Ryoishikawa's Avatar
Ryoishikawa
I have the breather blank and a Zetec turbo sump for sale if you need them
Old Aug 27, 2012 | 08:46 PM
TomPengelly
Kapow!!
Ive just bought the blanking plate. Is your sump a 1.8 or a 2.0? As i need a 1.8 sump so my exhaust clears?
Old Aug 27, 2012 | 08:52 PM
Ryoishikawa
1.8 . Can send you picture . Send me pm .
Old Aug 28, 2012 | 07:34 AM
Rick's Avatar
Rick
Don't block it off, it needs to breathe as much as possible!
Old Aug 28, 2012 | 08:00 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
i still have mine somewhere, its got a -12 fitting. but unfortunately due to the extension i know its at the back of the shed and im fucked if im taking all that out again any time soon
Old Aug 28, 2012 | 08:58 AM
RS-Rikki's Avatar
RS-Rikki
I had loads of problems with clanking plate I could not get a seal on my manifold get a 40mm core plug so easy I did put a bit of rtv sealant round it as I put it in works a treat
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
