Differance between 1.6 16v zetec s and 1.6 16v zetec se engines
Old Aug 27, 2012 | 03:15 PM
XR2Monkey's Avatar
XR2Monkey
Default Differance between 1.6 16v zetec s and 1.6 16v zetec se engines
Hi guys my MK1 focus 1.6 16v Zetec-s engine has just developed a terminal knocking noise so will need to be changed i was wondering if the 1.6 16v Zetec-se would go straight in????
Old Aug 27, 2012 | 03:42 PM
mattxr3i's Avatar
mattxr3i
Yep, same engine. Why not look for a cheeky Puma 1.7
Old Aug 27, 2012 | 03:47 PM
XR2Monkey's Avatar
XR2Monkey
chears mate so i wouldnt need to change the ecu or anything?
Old Aug 27, 2012 | 04:38 PM
Bailes1992's Avatar
Bailes1992
Your S will have a MAF sensor and your SE will have a MAP sensor.
You can either just not plug the MAP in (It's located in the inlet manifold) or you can put your inlet manifold from your original engine on the new engine.
Either way the Sigma engines as they are known are terrible!
What mileage did yours fail at?
Got rid of my Focus after spending thousands getting it upto standard. Then in 3 weeks at 92,000miles the engine started knocking and the gearbox blew up.
A 1.7 wouldn't be easy to fit, you'd have to build a custom engine loom and some other wiring modifications to take the Fiesta ECU. not only that it uses a complete different immobolisor system. I looked into it for mine.
I was thinking about fitting a 1.6 Zetec from an Escort into mine (abit slower and old fasiosn but much more reliable) and using a 1.8/2.0 Focus engine loom & ECU but decided it was not worth the hastle.
Old Aug 27, 2012 | 04:53 PM
XR2Monkey's Avatar
XR2Monkey
Thanks for the info mate mine started knocking 155,000 miles now its at 161,000 miles and is toasted lol!
Old Aug 27, 2012 | 06:01 PM
martysmartie's Avatar
martysmartie
That is your opinion, no offense by your own admission you say that you had spent thousands getting your particular example up to standard, so by that fact alone suggests your car was duff in the first place!
161K isn't bad going!
As said the earlier ones had MAf sensors and the later ones had TMAP's.
The knocking is typically a sign that the big ends going to go.
There actually not bad engines and are popular among kit car's.
Martin
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Dubs44
Aug 21, 2015 02:42 PM
