vvt solenoid st170
Old Aug 15, 2012 | 07:26 PM
seddo's Avatar
seddo
Default vvt solenoid st170
Hi guys just wondering when this solenoid actually begins to work at like which rpm? What are the symptoms of this beginning to fail. My car has has low poer across the rpm ranfe. I tend to have to use more throttle an car has no power bursts like it used to.
Thanks for help guys
Old Aug 16, 2012 | 12:19 AM
Walker R.S's Avatar
Walker R.S
I have this very problem!
I got my ST170 a month ago, and the throttle response is practically none existent?!
Revving from idle it is Very unresponsive and driving through the rev range in each gear it is just really slow.
I have replaced both pre and post cat lambdas as they Dyed on me.
I would be very keen as Seddo to any light being shed on this issue??
(Not my only issue)
I have had it in the air 4 times so far looking for an exhaust leak which is non existent! I am pretty sure the ST170 is suppose to have a grunty sound to usual ..... mine sounds like it is blowing really bad from the front or underneath but looking there is no sights or sounds of a blow anywhere!
Secondly The top end has A Follower slapping tapping sound from the top end .... Also pretty sure this should not sound so rough .... or do they usually?
I am a more classic Ford owner usually with the XR2I's/3I's, Escort GTI's, RS Turbo's and Most recent my RS1800 So a 2002 motor is All German to me when it comes to the Different bits on the ST170
Any help would be a great help in clearing up my issues?
Thanks in advance
JAY
Old Aug 16, 2012 | 04:40 AM
oldford's Avatar
oldford
Jay, have you checked the cat? Might be blocked.
Old Aug 16, 2012 | 01:27 PM
seddo's Avatar
seddo
Hi jay guess what? We have the same exact problems it seems. The top end on mine has started to sound like the old fizzbomb an I'm worried there something up with the engine. It defo sounds like the tapping is coming from the engine where the downpipes bolt and also the exhaust resonates so badly it does sound like a leak although I can't find any either. Would a broken down cat through up a fault or engine light?
Old Aug 18, 2012 | 09:41 PM
seddo's Avatar
seddo
anybody got a vvt solenoid for sale?
Old Aug 21, 2012 | 05:52 PM
Walker R.S's Avatar
Walker R.S
Have changed exhaust manifold Gasket .... No difference.
I have more than enough back pressure to Rule out the Cat being blocked.
Driving it to town today and Noticed on my way back it got some balls from somewhere and had some go, the reason i noticed this so much was not only did it pick up with more throttle response but the "Blowing" wasnt as noticeable, Also the engine note completely changed from a flat single note to an almost V6 sort of sound ...... Starting to think about the VVt in more depth, only problem is I dont really muck around with the VVt side of things so not certain where Wiring/Solenoid or if infact it is atall working and the engine note changing is the VVT kicking in and then stopping working again?
It is very confusing to say the least
Any other ideas or previous experience in this issue?
A bloody nightmare hey Seddo .... Have you got any further with yours?
JAY
Old Aug 21, 2012 | 09:52 PM
seddo's Avatar
seddo
Hi mate upto now my car has been working great and its since I unplugged vvt solenoid an checked inside it. Was full of oil an not sure how it has enters but must be a bad solenoid. Gave connections good clean an now car runs great. Just give yours an check just incase doesn't have a good enough connection
Old Aug 21, 2012 | 11:21 PM
deano2690's Avatar
deano2690
have you checked the inlet manifold runner control thing? normally brings the engine management light on but still worth checking?
the STs have solid lifters so there all noisy top end i believe. just done a full service on mine and it still sounds like a TDCI lol
Old Aug 21, 2012 | 11:24 PM
deano2690's Avatar
deano2690
And I believe the VVC set up is on CONSTANTLY, not at set RPM's like a puma or similar.
Old Aug 21, 2012 | 11:45 PM
chocolatecookies's Avatar
chocolatecookies
hi i have a spare vvt solenoid for sale as i no longer need(have catcams)send me a pm if you want
Old Aug 23, 2012 | 04:46 PM
Walker R.S's Avatar
Walker R.S
Which is what leads me to believe mine kicks in and out when it feels like it as it either goes well or shit
Mostly shit though lol
VVT Needs a serious talking to I think!
JAY
Old Aug 27, 2012 | 08:01 PM
telf's Avatar
telf
I would check the imrc, if its not working correctly power in the low rev range is crap
good thread here for tips and general info on location etc -
https://passionford.com/forum/techni...141-p1518.html
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
dombanks
Sep 21, 2015 08:38 PM
markk
Sep 9, 2015 08:11 AM
