Saphire electric sunroof, what's needed?
thinking about doing this conversion on my saph, just wondered what i needed form the doner car as i can get them all together.
Pete, you will need a car with one already fitted to get the full kit.
You can use another motor etc....but you will need the sierra bracket that holds the motor in place.
1. plastics,buttons etc..
2. motor.
3. bracket.
4. wiring, this can easily be made.
5. all the screws, bolts etc...
Then the important bit!!
Make sure the motor you get fits the splines in YOUR roof.
I had a late roof motor and it did not fit a 'h' plated car roof as the splines were different, you have to get another motor from a granada or the sunroof from the car which the kit came off.
Any probs give me a p.m.
Dave.
2. motor.
3. bracket.
Dave.
Originally Posted by XR4Timan
Dave is correct - good advice mate - just one thing! If the splines are Peter Tong, pull the whole sunroof assembly out of that J-K reg Sapph and do a transplant.
Check wether the splines fit your roof first before you buy it.
Steve DOHC, tried that one,
fooked the roof up.
Dave.
borboyous
Aug 22, 2015 11:17 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
