Airtec Plenum vs Spacer
Old Aug 14, 2012 | 09:23 AM
kiwikermit's Avatar
kiwikermit
Default Airtec Plenum vs Spacer
How much better is the Airtec plenum when compared with a standard Cosworth plenum running a spacer?
Old Aug 14, 2012 | 10:19 AM
MADMAXPTT's Avatar
MADMAXPTT
I want to find out exactly the same thing!
And how Airtec plenum behave with a spacer?
Old Aug 14, 2012 | 11:59 AM
stu21t's Avatar
stu21t
I know the hart plenum had a much better distribution of air than a std plenum, nearly all 4 cylinders got the same amount which they dont on a std plenum with or without a spacer.
And the airtec is a copy of the hart so "should" be the same.
Old Aug 14, 2012 | 03:49 PM
GARETH T's Avatar
GARETH T
Define better?
Old Aug 14, 2012 | 04:26 PM
Rsmat's Avatar
Rsmat
As Gareth says define better.?... As I'd like to know.
Old Aug 14, 2012 | 05:27 PM
stu21t's Avatar
stu21t
Do you mean me?
I mean more even distribution of air to each cylinder.
Im sure i remember being told that Individual cylinder egts were measured on the dyno and with the hart plenum they were within 5% of each other.
Bare in mind i was told this way before they were on sale, a few years ago, so i might not have remembered it exactly right.
Old Aug 14, 2012 | 05:35 PM
kiwikermit's Avatar
kiwikermit
That is the sort of info I mean by better. Improved distribution sounds like a good start. What about throttle response? HP and Torque differences?
Old Aug 14, 2012 | 05:39 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Ive also been looking in to this, im going to settle for a spacer until some facts and figures are available.
Old Aug 14, 2012 | 09:14 PM
GARETH T's Avatar
GARETH T
To be honest, I haven't got any facts. When you are tryin to compare anything you need to deside what we are judging them on
Old Aug 14, 2012 | 10:27 PM
kiwikermit's Avatar
kiwikermit
What about people who have fitted Airtec plenums then? Anyone got any experiences with them?
I'm just trying to make an informed decision on whether they are worth the extra cash and fitment issues when compared with a spacer. Are they worlds apart or is the difference hard to pick?
Old Aug 15, 2012 | 08:06 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Back to back test RS500 plenum against the Hart no other changes the Hart made an extra 37bhp on Norris Designs dyno. We are talking high end Spec here but something was working better thats for sure they were both spaced. Why buy a copy the Hart is proved to work never neard of such a result on a blatant cheap copy.
Old Aug 15, 2012 | 08:11 AM
Jay,'s Avatar
Jay,
Sponsor
Well ill tell you now rod the hart was copied yes but after fitting both types id rather use the AS one as the hart finish threads ect are like a 5 year old has made them
Old Aug 15, 2012 | 08:16 AM
Rsmat's Avatar
Rsmat
Well I'm intrigued to know if the AS is a direct copy then how come the hart performs better ?
Old Aug 15, 2012 | 08:28 AM
Jay,'s Avatar
Jay,
Sponsor
cant really compare as each car will be different so you need a back to back tests on the same car/map
Old Aug 15, 2012 | 08:33 AM
kiwikermit's Avatar
kiwikermit
The RS 500 spec vs Hart gives a pretty good indication these are a good upgrade then.
Old Aug 15, 2012 | 08:37 AM
Rsmat's Avatar
Rsmat
So is it true to say up til now they havnt been tested back to back..?
Old Aug 15, 2012 | 08:43 AM
Jay,'s Avatar
Jay,
Sponsor
not that ive heard but could of been Matt . I did a fair bit of messing with 2wd/4wd and eec4 manifolds with and with out spacers a few years back and when the spacer was added to each manifold the car leaned off giving the indication that there was more air being passed so = more power but i never got to egt test each cylinder to see how that was
Old Aug 15, 2012 | 08:52 AM
Rsmat's Avatar
Rsmat
Ah cool mate...
gcfcos
59
Oct 6, 2015 05:04 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
Russ Payne
Sep 25, 2015 08:29 PM
timsrs
22
Sep 24, 2015 08:14 PM
