What will remove Cosworth rocker cover paint?? PAINTED and MACHINED
Old Aug 13, 2012 | 02:55 PM
adam151082's Avatar
adam151082
Default What will remove Cosworth rocker cover paint?? PAINTED and MACHINED
I need to remove the paint off my Rocker cover and the B&Q paint and varnish remover didnt touch it. any ideas what will?
If anything i think it gave it a better finish
Old Aug 13, 2012 | 03:24 PM
flannigan's Avatar
flannigan
Sand blasting !
Old Aug 13, 2012 | 03:25 PM
coswurv's Avatar
coswurv
nitro morse, is what i used with a wire wheel
Old Aug 13, 2012 | 03:46 PM
wattie's Avatar
wattie
I used some industrial paint stripper from work, nitro morse should do the trick but I've found it's not as strong as it used to be
Old Aug 13, 2012 | 06:05 PM
mattman1234's Avatar
mattman1234
sandblast it,quick and easy
Old Aug 13, 2012 | 06:26 PM
adam151082's Avatar
adam151082
Sandblasting would be easyer but i was after something i could do myself.
Old Aug 13, 2012 | 07:25 PM
costina's Avatar
costina
Live long and prosper!!
Nitromors as said job done
Old Aug 13, 2012 | 07:42 PM
tezmanian devil's Avatar
tezmanian devil
+1 works a treat
Old Aug 13, 2012 | 07:47 PM
mattman1234
have you an air compressor
sandblasting guns are about a tenner
wickes for the dry sand
paul16v's Avatar
paul16v
Monte 087
I always sandblast them.
Old Aug 13, 2012 | 07:49 PM
coswurv's Avatar
coswurv
If you do use nitro morse and a wire wheel, wear a long sleeved top, safety goggles and some gloves as its evil shit, make sure you get all the red off otherwise it will show up as lump s under the new paint, mine come out like this after i stripped, etch primed, base and laquer
Old Aug 13, 2012 | 09:04 PM
adam151082's Avatar
adam151082
Ok thanks, is the wire bush needed or will it just start to lift and peal off its self?
Old Aug 14, 2012 | 11:40 AM
coswurv's Avatar
coswurv
It does need a bit of encouragement yeah.
Old Aug 14, 2012 | 11:59 AM
daviddunlop83's Avatar
daviddunlop83
I have used nitromorse too.
Tho best result was sandblasted then powercoated and machined.
Old Aug 14, 2012 | 09:08 PM
adam151082's Avatar
adam151082
Ok, so after having no luck with the B&Q stuff i went and bought some Nitromorse and painted it all over the cover
Left it for a bit and gave it a 2nd coat, left it for 40ish mins then attacked it with a wire brush
It didnt work to well so i gave it another two coats and wire brushed it again
A little disapointed i took it to work and spent 3hours with emery cloth to get this
Going for paint tomorrow
Old Aug 14, 2012 | 09:12 PM
Rossy43's Avatar
Rossy43
Fiesta ZS. FF feat nov'11
Take it to a local powdercoaters and ask um to sandblast it with their next batch of stuff. Should be pennys, if that.
Old Aug 14, 2012 | 10:00 PM
adam151082's Avatar
adam151082
I will be next time, spent £16.50 in paint stripper
Old Aug 15, 2012 | 08:32 AM
coswurv's Avatar
coswurv
I can only say fair play to trying it with a wire brush, i used a wire wheel on the drill, much more affective and took about 20 mins.
Old Aug 15, 2012 | 08:13 PM
adam151082's Avatar
adam151082
Painted
Old Aug 15, 2012 | 08:52 PM
cossiestu's Avatar
cossiestu
Looking good! Will do mine one day.....
Old Aug 15, 2012 | 09:01 PM
cossiestu's Avatar
cossiestu
Did you use primer on it?
Old Aug 15, 2012 | 09:04 PM
Rsmat's Avatar
Rsmat
Should have just sent it me and id have blasted it you mate.
Old Aug 15, 2012 | 09:08 PM
BigErn's Avatar
BigErn
Ah, I guess it was you who text me then? I been phoneless due to it fucking up and just dug out an old warhorse to use for now but Ive got no ones number. should have took it to SEM and got it blasted, probably would have only been a tenner or something.
Old Aug 15, 2012 | 09:32 PM
zippyobrien's Avatar
zippyobrien
Gotta be honest mate looked better in the first pic after u BBQ cleanered it
Deffo blast and powdercoat
Old Aug 15, 2012 | 09:37 PM
Cossy Mike's Avatar
Cossy Mike
Vapour blasting is the only way....anything else and you'll loose the original 'grain'
I've done mine and it would pass for new factory look.
Vapour blast, dust coat 2k primer, de nib it, very light coat of 2k VW torando red, satin laquer (very light) then machine off with a 5 inch pad for the matt swirl finish.
Can get pics if needed......
Blasting will kill it and powder coat is way to thick
Old Aug 16, 2012 | 04:24 AM
I think it looks ok now.
Old Aug 16, 2012 | 11:40 AM
adam151082's Avatar
adam151082
Ill admit it looks a bit shiney under the lights in work, if it looks crap after ive skimed the top layer of paint off iill just re do it. Quite fancy that crackle finish but in red.
Old Aug 16, 2012 | 06:11 PM
adam151082's Avatar
adam151082
Well its done and it looks loads better
Put it on here
Old Aug 16, 2012 | 09:00 PM
Vann1992's Avatar
Vann1992
I clean CNC lathes for a living.
No idea how to use one, haha.
Old Aug 16, 2012 | 09:48 PM
vaughant's Avatar
vaughant
I think it looks the bollox,a little nick on the 2nd plug cover from the bottom or a bit of stray paint?
Old Aug 16, 2012 | 09:54 PM
J1mbo's Avatar
J1mbo
B1mbo
Good job mate, anyone reading, do not sand blast the cam cover, infact no engine parts, the sand embeds itself in the material and when hot the vibration sends it through the engine, seen many engines wiped out just after cam covers have been refurbed.
We have all our engine parts aqua blasted, it's more expensive but not in the long run.
Old Aug 16, 2012 | 10:24 PM
adam151082's Avatar
adam151082
What part do you clean? its a milling machine in the picture but i mostly do turning
Theres a nic in the cover m8
Good advice m8
Old Aug 16, 2012 | 11:31 PM
Vann1992's Avatar
Vann1992
[QUOTE=adam151082;6010753]What part do you clean? its a milling machine in the picture but i mostly do turning
Whatever the customer wants really, internal, external, swarf bins, pillar drill & cranes are the normal.
Never had a job that was to big tbh, internal & external can be pricey though as it normally takes around 4 hours to clean a mid sized lathe.
Most of the time it's overnight jobs so that they don't have to shut the machine down.
Old Jun 23, 2013 | 09:36 PM
adam151082's Avatar
adam151082
Just been re-reading this and a realised id forgot to add a finshed pic
paint still looks great and is well baked on
Old Jun 23, 2013 | 10:09 PM
stuboy's Avatar
stuboy
looks very nice
Old Jun 24, 2013 | 07:55 AM
Very smart matey.
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
Aug 14, 2015 07:29 AM
