Mk3 Mondeo door locking control module
Old Aug 12, 2012 | 08:20 PM
RichieST's Avatar
RichieST
Default Mk3 Mondeo door locking control module
Evening all
Having some issue's with my mondeo's central locking. Have done some digging about and it seems that it's the control module that's at fault. Does anyone know where abouts on the car it's fitted?
This is the unit I'm looking for
Rich
Old Aug 12, 2012 | 08:30 PM
dojj's Avatar
dojj
Resident Wrestling Legend
In the drivers door as its the master controller for the central locking
Unless its your gem playing up as this also does stuff
Old Aug 13, 2012 | 08:01 AM
RichieST's Avatar
RichieST
Thanks Dojj, problem is when locking with the remote, the locks just ping open again, when locking with the key in the door the doors lock apart from the nearside rear door. Also the boot release button on the dash doesn't work and the boot release button under the handle works sometimes.
Also, with the engine running, slam the drivers door and the doors will either lock or unlock themselves.
so do you think it's the unit inside the drivers door and not the GEM unit?
Old Aug 13, 2012 | 12:37 PM
dojj's Avatar
dojj
it may be the wires in the door for the central locking, getting the plugs apart is really a right pain in the arse of a job to do
if the locks are opening again it would point to something sticking
do they lock internally or not?
when i had problems with my central locking it was the module that was at fault, but i also broke one of the locking cables while i was doing the swap and then i managed to lock myself int the car and it wouldn't open
go to the door that has the issue and remove all the mechanism that does the central locking and see if it works when it's free, at least you can eliminate the motor and do a bit of guess work as to where the porblem may lie if it's mechanical rather than electrical
the boot popped nearly always tends to be the actual microswitch in the tailgate being dry, open it up and grease it and 9 time out of 10 this solves the problem
be careful though, it's a bit delicate
Old Aug 13, 2012 | 01:14 PM
RichieST's Avatar
RichieST
Thanks for the info Dojj! The N/S/R door lock doesn't move at all, regadless of weather you are locking or unlocking with the remote, or the key in the drivers door. The only way to lock or unlock it is manually operating the lock from inside the car. If I leave the rear door unlocked then lock with the key, the other 3 doors will lock ok without pinging open, but the N/S/R door stays unlocked.
I've ordered a new rear door latch from ebay, I'll get that on and go from there
Old Aug 14, 2012 | 09:52 AM
daviddunlop83's Avatar
daviddunlop83
Could be the actual door lock itself.
Mine had a faulty micro switch in it and it did all sorts of mad stuff with the central locking.
Is the control modual you mean not the GEM module Dojj is talking about? If it is the GEM one it wont be cheap as it needs programmed to the car, it controls loads of stuff from central locking, how long heating front screen stays on, the way rear wiper comes on when in reverse if front wipers are on etc
Old Aug 14, 2012 | 10:31 AM
dojj's Avatar
dojj
Gems are cheap mate, Ł20 will get you one and you need 30 seconds to reprogram it
The issue comes when you get a gem with the wrong numbers on it
It's up by the drivers side above the accelerator pedal and you have to unplug it a certain way as well before you remove it
If you ask over on talkford.com for a guy called Alex of lxxy I think his user name is, he will probably be your best bet
There are plenty of write uos there too if you can navigate your way around the wiki page
Old Aug 14, 2012 | 10:37 AM
daviddunlop83
Ahh cool, when i looked before i thought it needed a full programme by ford.
Old Aug 14, 2012 | 10:59 AM
dojj's Avatar
dojj
They will work without programming too, but the key won't remote lock, which is sort of what he wants to fix
Old Aug 14, 2012 | 02:44 PM
RichieST's Avatar
RichieST
New rear door lock mechanism turned up today so I'll get that fitted probably over the weekend and see what happens then!
Old Aug 14, 2012 | 08:25 PM
D-Sport's Avatar
D-Sport
I have a 2007 petrol Mondeo with the rear passenger side door not locking when locked with key in door lock or with remote
the thing that locks the door above the door opening handle won't click inwards to lock it and is stuck
Any idea what the problem is
Old Aug 14, 2012 | 09:02 PM
dojj's Avatar
dojj
there is a little red cover on the locking cable which stops it from popping out
this had snapped on mine and was the cause of this
a new one from ford is about Ł8 and easy enough to replace
Old Jul 27, 2013 | 11:50 AM
Firepoichris's Avatar
Firepoichris
Hi to everyone the onthe forum . once again sorry about bringing this post back up from the ashes. My problem is a bit different. Now all my door locks are operating as they should when I can get the car to lock but my problem is when lock my car the car locks and deadlocks but when I open the car some times all doors unlock and some times its just the drivers door now im unable open my boot with the button on the dash or trigger on the boot or the button on the fob. I have to use the key to open it manually. now when I lock the car with the key their is no response. I can some times. which is rare of course lock the car with the key BUT it just unlocks its self again if I lock the car manually by the key all doors lock and deadlocks followed by the flashing indicators. Would u guys say that my fault lies in the central locking module as I believe it does as the problem with the fob not responding which does have a new battery. My Mondeo is the mk3 2001 tddi 5 door hatchback thanks chris
Old Apr 29, 2014 | 02:14 PM
Tatyanka's Avatar
Tatyanka
A great*exchange of information.
Old Apr 29, 2014 | 02:19 PM
dojj's Avatar
dojj
the deadlock when you drive off is a fault of the motion auto lock, which should unlock when you stop
Old May 1, 2014 | 09:35 AM
daviddunlop83
Mine doesn't unlock when you stop, you just pull the handle as normal tho to get our.
Never has and didn't on my old mondeo or a friends.
Old May 1, 2014 | 12:27 PM
dojj's Avatar
dojj
mine deadlocks when it moves away and the only way to unlock it is when i turn the ignition off
andyrs1600i
Apr 29, 2026 03:21 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
PaulinhoT
Oct 28, 2015 06:06 PM
leep27
Aug 22, 2015 01:52 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
