traction control light
Old Aug 10, 2012 | 09:19 AM
tetsuo st's Avatar
tetsuo st
Default traction control light
Hi I have a focus st 2 08
and traction control light is permanently on can anyone help
Old Aug 10, 2012 | 11:48 AM
Farmer Giles's Avatar
Farmer Giles
Does the ABS still work ?
Could be a simple as a wheel sensor has failed but easiest thing it to get it plugged in and have the codes read then you will know exactly what's wrong.
hth
Old Aug 10, 2012 | 01:19 PM
Jeff Collision's Avatar
Jeff Collision
The ABS unit might be lacking. Check under the airfilter box for red wire. It may be partially chewed off by the edge of the airfilter box itself.
Old Aug 10, 2012 | 01:34 PM
R5FORD's Avatar
R5FORD
If abs was faulty it would go into limp mode.
Old Aug 10, 2012 | 02:32 PM
B19 JUB's Avatar
B19 JUB
i reckon abs/esp module is faulty.best to get the codes read first then start from there.more than likely come up with brake pressure sensor fault which is incorporated into the unit unlike fiesta st which is a seperate sensor on the master cylinder
Old Aug 10, 2012 | 07:08 PM
James's Avatar
James
almost certianly abs pump, cost is about £300 + vat at dealer
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Kam B
Sep 24, 2015 10:40 AM
landaqmabba
Sep 15, 2015 07:16 PM
The Enigma
Sep 12, 2015 10:12 PM
markk
Sep 9, 2015 08:11 AM
