Ford KA Discuss your Ford KA here!
Gearbox help
Old Aug 9, 2012 | 07:07 PM
davek1's Avatar
davek1
Default Gearbox help
Need help I've got a sportka I'm changing the clutch next weekend and was thinking about putting a different gearbox in if you can as I mostly do motorway mileage and at 70-80 it's reving it's nuts off.... But what other gearbox could I put in it
Thanks Dave
Old Oct 2, 2012 | 01:58 PM
Shonky's Avatar
Shonky
V6 Ka of Love
Thanks Dave
The ratios in the 1.3 duratec box are different, not sure which way though lol but you might be able to find out
Old Nov 10, 2012 | 10:29 AM
Hobomassiv's Avatar
Hobomassiv
I think the 1.3 is longer. The sportka had different ratios so ford could fap over the 0-60 time or something like that.
Mine was at about 3500rpm at 70mph with 16 inch wheels (standard sizE)
Old Jul 2, 2013 | 06:39 AM
davek1's Avatar
davek1
Anyone as I still need to do this
Old Jul 2, 2013 | 09:17 AM
delbee1's Avatar
delbee1
The puma box
1st Ka 3.58 Puma 1.7 3.15
2nd Ka 1.93 Puma 1.7 1.93
3rd Ka 1.28 Puma 1.7 1.41
4th Ka 0.95 Puma 1.7 1.11
5th Ka 0.76 Puma 1.7 0.88
Final Drive
Ka 4.06 Puma 1.7 3.82
Old Jul 2, 2013 | 01:37 PM
davek1's Avatar
davek1
Hi thanks for that can I use the same gear linkage and is it a direct replacement ie mounts and speedo drive
Thanks dave
Old Jul 4, 2013 | 10:20 AM
delbee1's Avatar
delbee1
Thanks dave
I would think things are in the same positions as its the same box, you might have to use your speedo drive, try find a box to compare yours with
Old Jul 4, 2013 | 07:49 PM
McCloud 85's Avatar
McCloud 85
The puma box has different mounts to it so nothing will line up as far as I'm aware.. Your best bet I think is to change 5th gear for a lower ratio gear as this will give you a higher speed at a lower rpm..
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
