Cooling Fans....
Old Aug 8, 2012 | 10:09 AM
KW-rscos's Avatar
KW-rscos
Default Cooling Fans....
How are they supposed to work on a standard Ford set up? If it sits on the engine side of the radiator, then should it suck cold air from the front of the car into the engine bay? or should it blow warm air from the exhaust manifold through the radiator and out the front grille? what is the most efficient set up for the cooling fans?
Regards, Kieren.
Old Aug 8, 2012 | 01:24 PM
mgtkr1's Avatar
mgtkr1
fans should always suck/blow cold from the front of the car through the radiator, wether there on the inside of the rad or o/side. typical on turbo cars is the fan on the o/side of the rad blowing air through the rad. a fan on the other side (engine side) sucks air through the rad. fan direction depends on the way the fan is wired or you can switch the fan itself so the blades point the opposite way. a fan should never pull hot air through the front of the car, first of all at 10mph+ the hot air would be blown straight back into the engine bay so the fan is essentialy locking in the hot air. the flow through the rad aids airflow through the rad and helps the heat escape (from front to back) also a fan on permanantly restricts airflow through the rad once on the move and should only really be on when air speed isnt fast enough(traffic jams ect)
Old Aug 8, 2012 | 04:08 PM
KW-rscos's Avatar
KW-rscos
Excellent, thank you, a previous owner has messed around with the fan wiring on my car and you have just confirmed my suspicions?! Much appreciated.
Old Aug 8, 2012 | 05:26 PM
foreigneRS's Avatar
foreigneRS
Testing the future
but they won't work very efficiently
Old Aug 8, 2012 | 09:44 PM
Brendan's Avatar
Brendan
struggling with reality
flow is from the front of the car to the back! if you are cruising on motorway at 70 the fan should't ever come on as you will have lots of air pushed through the engine bay by the car moving through the air - more even than the fan can shift!
Chas
Oct 5, 2015 07:13 PM
`spotty
Sep 25, 2015 11:41 PM
coscor86
Sep 20, 2015 01:21 PM
rogerxr3i
Sep 13, 2015 06:56 PM
Si B
Sep 12, 2015 06:49 AM
