Tips on 1/4mile racing
Old Aug 3, 2012 | 05:14 PM
Joe91's Avatar
Joe91
Default Tips on 1/4mile racing
Tomorrow I'm off to a local abandoned airstrip as the is a drag racing event for any cars..
Basically can anyone give me some tips on launching etc or not launching, 2nd gear launching or anything that will help me!
I have launch control on my omex ecu but havnt had it mapped in yet
Thanks, Joe
Old Aug 3, 2012 | 05:26 PM
Benni's Avatar
Benni
Ban[B][/B]ned
What car is it mate? Will help people give you some tips! Hope everything goes okay for you though!
Benni
gjh's Avatar
gjh
lets some air out of the tyres for a bigger foot print, take any uneeded weight out of it, and practice, pratice, practice. What car do you have? rear wheel drive? 4 wheel drive? Front wheel drive?
Old Aug 3, 2012 | 05:29 PM
Fast Guy's Avatar
Fast Guy
What car do you have? fwd/rwd/4wd? what power/weight?
I wouldn't use 2nd gear, you could possibly kill your clutch or gearbox.
If you get to the start line 1st it can give you a few extra seconds to compose yourself, rather than rush if you're 2nd.
Reaction times don't add to your 1/4m time so go when you're ready, don't rush and end up wasting a run.
try shallow staging.
http://www.modernracer.com/tips/dragracingbasics.html
Old Aug 3, 2012 | 05:56 PM
Joe91's Avatar
Joe91
Sorry it's a series 2 escort, Not sure on power because I'm still on my running in map so I'm only running 6psi or so..I've got a 4 paddle clutch if it's helps, I want to see my times on this map then it's on agai next month so I'll get back up to Norris Motorsport for a proper map and hopefully run around 280bhp ish.
Thanks, Joe
Old Aug 3, 2012 | 05:58 PM
Joe91's Avatar
Joe91
Sorry I forgot its fully stripped out and caged etc so I have as little weight possible anyway.
Thanks, Joe
Old Aug 3, 2012 | 06:22 PM
stuart collins's Avatar
stuart collins
u wont have enough power for 2nd gear launch and probly do the box and clutch, just do sum runs and see how it feels every car is different , put semi slicks on it and start with 15psi and go down to 10 or 8 and see what difference it makes , find the bit hold it on the handbrake at 4k ish and then go for it
2nd gear burn out helps if u can get it goin lol
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
Si B
Sep 12, 2015 06:49 AM
