Wheel alignment issue?
Old Aug 2, 2012 | 12:43 PM
oVerboostUK's Avatar
oVerboostUK
Default Wheel alignment issue?
My Fiesta RST developed a problem last week where it felt loose when cornering and backing off from high speeds.
I had the suspension arm replaced as there was play on the passenger side arm. However, they did not do a wheel alignment check but assured me it should be okay as they didn't need to move anything other than swapping the arm.
The car feels better, but it's still unstable and not very balanced when driving. Feels loose and vague. Anyone else had this? Everything else feels okay, shocks and springs are okay, bushes all seem good...
The inner edges of the tyres at the front are slightly more worn but that's due to the worn arm that was replaced I think.
Would an alignment solve my problem, or could it be anything else, going by your own personal experiences?
Not enjoying the fiesta right now, and want it back to its best. Wheels are 16" with Toyo proxy tyres all round
Thanks.
Old Aug 2, 2012 | 02:36 PM
Oranoco's Avatar
Oranoco
If the arm has been changed, chances are the alignment will be out. Were the genuine Ford arms as the FRST ones are unique and pattern ones are not available (last time I looked). I would also change them as a pair.
Check the arm fitted is correct, if it's good get the alignment done.
Old Aug 2, 2012 | 03:04 PM
darrenb16two's Avatar
darrenb16two
Who replaced the arm and was it definatley the right one. Had this on my dads FRST and the arms we put on were a couple of mm to long
Old Aug 2, 2012 | 03:14 PM
oVerboostUK
I work at a Ford main dealer, and they were fitted here. The part was paternity but bought from a trusted local supplier, it measured the same as the old one. The part number was unique for the RS model too, but the tracking wasn't checked as I say but was assured it'd be okay.
Old Aug 4, 2012 | 04:28 PM
oVerboostUK
Sorted, swapped back wheels to front and also the front toe in was completely out, so had this adjusted and the car drives amazingly well now! Thanks for all the replies/advice etc.
Old Aug 4, 2012 | 04:40 PM
smudger068's Avatar
smudger068
You can get a free tracking check in most garages now adays anyways, so worth a look, setup and geometery is normally the culprit if not then it normally comes down to play and in extreme cases the chassis being bent if it has be pranged or whatever
Old Aug 4, 2012 | 05:41 PM
STeve's Avatar
Super Moderator
lesson learnt there chris never trust someones opinion always make sure the job is done right, both arms and tracking is a must
JK12
33
Apr 26, 2021 12:09 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
