Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Mk1 flickering headlights !?
Old Jul 29, 2012 | 10:49 AM
Lee-87's Avatar
Lee-87
Default Mk1 flickering headlights !?
Hi again all , mrs noticed last night whilst i was following her home that my headlights are flickering on dipped beam to the point that she actually pulled over as she thought I was flashing her , when I parked up at Home I sat there in the car with it running and the lights on and sure enough every now and again it gives a flicker , almost like a power surge or something is this a common issue or has it been heard of , just got the car and dont really know much about focuses
Old Aug 1, 2012 | 08:24 AM
furry's Avatar
furry
DECODING JIBBA JABBA!!
mr greeeeeening
not heard of this one before i will do some investigation!!
Old Aug 1, 2012 | 09:09 AM
Lee-87's Avatar
Lee-87
Hello mr fur !!!!!!! Thanks very muchly
Old Aug 1, 2012 | 12:40 PM
furry's Avatar
furry
sounds like it could be damp in a connector or a bad ground.
try unplugging the lamps and checking the terminals and cleaning the earth up
Old Apr 13, 2013 | 05:05 PM
Mk2 Mondie Oli's Avatar
Mk2 Mondie Oli
I am having the same problem although every light flickers dash included, some mentioned to me about the alternator being on its way out so I bought a tester but don't know where to attach connectors on the alternator to test it
Old Apr 13, 2013 | 05:37 PM
Lee-87's Avatar
Lee-87
My headlights dip from time to time but I think the battery is dieing as the indicator on the top of it is red lol the actual flickering I was referring to seems to be the drivers side bulb holder rattling slighty which is magnified hugely when driving at night, I'm yet to sort it out tbh.
Old Oct 3, 2013 | 10:03 PM
-neil-'s Avatar
-neil-
Did you sort this out?
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
Tank Mike
Sep 26, 2015 08:07 AM
