Cam belt Condition
Old Jul 28, 2012 | 09:15 PM
Jasoncmor's Avatar
Jasoncmor
Default Cam belt Condition
Hi all.
My cam belt is well over due now, I am currently working on my car to replace the clutch and cambelt.
My car has got 100k on the clock now and I'm assuming the cam belt is 15 years old. I've check my service history, (from the previous owner, and I bought through a ford garage) and there isn't really any details on the services, other than the stamps. I've owned the car for just over 6 years and the car only had 45k on the clock, so would have been 9 years old, so I don't know weather the ford garage would have changed the cambelt or not. The cambelt looks good I think, the edges on the teeth are slightly ragged, the surface doesn't have any cracks, but it has a path (is the only way I can descrive it) in the middle where I assume the water pump is running along it? But other than that the condition looks good.
Is it worth replacing or carrying on with it?
Btw, car is a mk4 fiesta, and the cam belt is garuenteed for 10 years / 100k miles.
Cheers, Jason
Old Jul 28, 2012 | 09:22 PM
jamie's's Avatar
jamie's
the general rule with timing belts is simple
if theres any question at all with it then change it
cost of a belt compared to cost of a top end rebuild when it breaks?
only makes sence to change it
oh and you say that its gauranteed for 100k miles,
no manufacturer actualy gaurantee's their belts, its just a recomended change interval,
thay always state that it should be inspected early and changed id required
so best to change it to be on the safe side
if it only had 45k when you bought it, then its unlikely to have ever been changed before
Old Jul 28, 2012 | 09:27 PM
john_p_b's Avatar
john_p_b
You've gone to the effort of taking it off to check it, spend 30 quid and stick a new one on then forget about it for a few more years.
Old Jul 28, 2012 | 09:37 PM
Jasoncmor's Avatar
Jasoncmor
OK, cheers for that
Jason
Old Jul 28, 2012 | 09:39 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
i'd leave it but then i prefer to change an engine than a belt
Old Jul 28, 2012 | 09:41 PM
Jasoncmor's Avatar
Jasoncmor
As much as i'd like to drop a puma 1.7 lump in there, I can't afford to spare that kind of money lol.
Old Jul 28, 2012 | 10:36 PM
mechanic28's Avatar
mechanic28
cambelt can like fine then snap the next day change her mate
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
sridgett
13
Sep 27, 2015 06:03 PM
cos elle
Sep 25, 2015 09:52 AM
dombanks
Sep 21, 2015 08:38 PM
