What Head geasket for T34 yb?
Jul 27, 2012 | 02:37 PM
What would be the recommended head gasket to use on a yb running T34.48, upto 30psi hopefully.
thanks
Jul 27, 2012 | 02:43 PM
My sapphire is same spec mate and running just a group A gasket. Been advised that the group A is perfect for this set up.iv also used multi layr steels b4 but no need,group A will be fine in my opinion
Jul 27, 2012 | 03:23 PM
I've same spec mate and I run grpA gasket and standard gen ford head bolts. Been fine for me.
Jul 27, 2012 | 03:32 PM
Mine was over 500bhp on a GrpA HG and standard head bolts
Steve
Jul 27, 2012 | 06:46 PM
I used cometic on my 4x4 just to be safe. I ran 34lb all day long no issues. Think piece of mind not cost.
Jul 27, 2012 | 06:48 PM
I've got a grpA one on mine with the same spec and it's been fine.
Jul 27, 2012 | 06:51 PM
ive got a brand new grp a gasket for sale if ur interested
Jul 27, 2012 | 06:59 PM
RS & ST Parts Specialists
I have YB1261s back in stock if needed Dave
Jul 27, 2012 | 07:42 PM
coopers O ring job done although a grp A would be fine lol
Jul 27, 2012 | 08:14 PM
If engine is in car then a group a! If it's out havin a rebuild go wrc!
Jul 27, 2012 | 08:24 PM
Has the head gasket defo gone?
Jul 28, 2012 | 05:37 PM
steel multi layer gaskets will require block and head faces to be perfect.
grp a and std bolts for me too and i'm running 30 psi
Jul 28, 2012 | 08:30 PM
Grp a and new ford bolts will hold that boost.
Jul 28, 2012 | 09:50 PM
Sticky: Don't know yet head not off yet, nearly though. Gona swap the head for my old one i think. I get out my wibble ruler to see which is flatest
Block is staying in the car, so think i'll stick with GrpA and std bolts.
Matt: I'll give you a call Monday
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
Russ Payne
Sep 25, 2015 08:29 PM
