Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
fiesta mk6 central locking problem
Old Jul 21, 2012 | 05:19 PM
ldefeo's Avatar
ldefeo
Default fiesta mk6 central locking problem
Hi all i have a mk6 2002 model fiesta zetec 1.4 but an issue with the central locking, i will try to explain as its a little confusing - at least to me
basically i can Lock ALL the doors from either the passenger or drivers side using the key
however if i try to unlock the doors it goes a bit wrong
from the drivers side the key turns the full way but only unlocks the rear door on the drivers side.
from the passenger side i cant turn the key (only a few degrees) hence unlock any of the doors
ive taken the passenger door apart to have a look i got myself a new locking mechanism (the solenoid part also) from the scrapyard. I plugged it in and behaves in exactly the same way when operating the key from the drivers side. This would indicate the problem is electrical?? note the solinoid seems separate from the key mechanism, i dont know how they connect.
But then again why doesnt the key turn on the passenger side, and why is it that both the doors dont unlock on the passenger side, and if its electrical why am i able to lock all the doors???
any help would be great
Thanks
JoeyBoyden
Jan 4, 2024 02:36 PM
23
Sep 12, 2015 12:56 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
