EEC IV 295 Chip
Old Jul 18, 2012 | 07:19 PM
the_frozen_one's Avatar
the_frozen_one
Default EEC IV 295 Chip
Anyone have experience of these? Any issues etc.
Just seems like a lot of power for stock injectors/turbo etc, I'm not convinced (but I'm prepared to be enlightened)
Old Jul 19, 2012 | 05:32 PM
James @ M Developments.'s Avatar
Yeah they work well, chip, -31, and ideally an ITP048 fuel pump and a nice set of plugs.
Old Jul 19, 2012 | 05:41 PM
the_frozen_one
Is that a replacement internal tank pump? A dash 31 scares me, it can be seen. The cars factory fresh would hate for an aftermarket actuator to stand out
Old Jul 19, 2012 | 05:54 PM
our -31s look the same as the factory items, only cleaner
the pump is in tank yes.
All the bits you need are on our webshop
http://www.shop.motorsport-developme...worth-18-c.asp
Old Jul 23, 2012 | 07:03 PM
the_frozen_one
You've never seen my engine bay
Will have a look and give it some serious consideration. Once the palpitations over non-standard parts have stopped.
Old Jul 23, 2012 | 07:18 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
James, is this a simple fit/set up or does it need a trip to MSD?
Old Jul 24, 2012 | 08:23 AM
Can be done DIY if you have the gear for fuelling checks etc.
Old Jul 25, 2012 | 10:56 AM
pieterjan's Avatar
pieterjan
Is this chip really 295bhp? are these better then the superchips one?
Old Jul 30, 2012 | 06:42 PM
The superchips ones ive seen run very lean at higher rpm, infact most run richer with the chip removed
Old Aug 2, 2012 | 09:13 AM
pieterjan's Avatar
pieterjan
Ok so i will look to buy one off you do you have some deals on thee lol!
Old Aug 2, 2012 | 10:09 AM
If you email steve your spec, im sure he can help you out as a regular customer.
Old Aug 2, 2012 | 07:12 PM
pieterjan's Avatar
pieterjan
I will contact hij tommorow about this! Thanks james!
Mile30
69
May 13, 2017 08:44 PM
tankybaby66
Feb 6, 2016 02:24 PM
STAFFY OWNER
18
Sep 21, 2015 02:50 PM
RSmark84
Sep 13, 2015 01:29 PM
