Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Idle Problem
Old Jun 30, 2012 | 05:35 AM
Bigd08ffc's Avatar
Bigd08ffc
Default Idle Problem
Hi, ive got a mk1 focus on an 03 plate that has an idle problem..... it idles very erraticly and i was told it was the idle air valve... that has been changed but it still has the same problem, any ideas?? it feels like it will cut out if left idleing and stutters, also on the top of the rocker cover not where the 4 holes are for the plugs but the centre hole with a cable coming out has a leak, any idea what the bung that goes there is called so i can order a replacement?? cheers guys
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
