Bonjours, I present you my RS2000.
She is at present in revision.
I wish to upgrade front brake in 280 mm but I have a small problem.
I do not find a brake disk of the good size not to use spacer and to keep ABS.
Could disks of fiesta ST150 suit?
Am using mondeo st200 discs and calipers the discs I have are 280mm and the only thng I had to do was bore the mounting holes out by 2mm for the calipers.
most of the non uk spec cars mark did not have the quality items we take for granted Mark , some models only had a zetec engine too but the more important question would be those pedals almost touching
Ive heard about the Brazilian or somewhere with a 1.8L engine before. Also jesus, yes just looked at those pedals, Thats pretty dangerous, MoT failure in the UK.
