switchable maps
Old Mar 2, 2005 | 07:19 PM
Moose 130's Avatar
Moose 130
Default switchable maps
is it possible for an ECU to hold two seperate maps?
eg; one for 91 RON fuel and one for 100 RON.
and if it is, is it possible to switch between the two?
(please lets not discuss the pros and cons between Autronic/SECS/L6?L8/P8)
Old Mar 2, 2005 | 07:20 PM
Benn 304R's Avatar
Benn 304R
im interestead in this aswell
Old Mar 2, 2005 | 07:22 PM
Porkie's Avatar
Porkie
I know Pectel T6 2000 can do this.
Old Mar 2, 2005 | 07:23 PM
ECU Monitor Enthusiast
If this is to do with cossies....
It is possible with extensive modifications and only the select few can do it on the factory ecu's.
However, if its only an ignition change you require,
the ignition is easiliy retarded for lower octane fuels by linking the octane connector.
This can retard the ignition by 2, 4 or 8 degrees depending on the car/ECU and chip fitted.
This will of course need proper testing with DET headphones on the new fuel
and also would probally require a boost drop to be safe too.
Oh and yes S8 does it !
Old Mar 2, 2005 | 07:27 PM
Moose 130's Avatar
Moose 130
Hyperthetical situation.
Take a cossie to the states, you can use 91 ron but also have available SUNOCO 100 ron fuel at the local drag strip.
Could you fill up with the good stuff, switch over the map and have fun.?
Old Mar 2, 2005 | 07:28 PM
GARETH T's Avatar
GARETH T
with cossie ecus you can piggy back the chips,, im sure msd sell a board just right for the job
with a t6 its alot easyer,,, well a flick of a switch
Old Mar 2, 2005 | 07:30 PM
GARETH T, With that method, it is easy to do on the factory ecu's too !
And way cheaper than a T6
Fit a chip with twice the memory size, load both programs and switch the
high order address line LIVE to change maps !!!
You would of course need two chips with suitable maps for each stage
that have a common base operating program.
Old Mar 2, 2005 | 07:35 PM
GARETH T's Avatar
GARETH T
i was on about doing it with two eproms,, but i guess a rom with twice the memory is a better way
Old Mar 2, 2005 | 07:39 PM
GARETH T, Still a valid way of doing it though !
I soldered two on top of each other before (one with proper flamer map in it )
[TECHIE ON]
Then gated the chip selects through some NAND gates (reverse logic dont forget)
via the original ecu chip select output.
[TECHIE OFF]
This is more complicated than the bigger chip way BUT works equally well
Old Mar 2, 2005 | 07:41 PM
Stu @ M Developments's Avatar
PassionFords Creator
We do this modification for almost any ecu that uses an Eprom for its run software as long as it doesnt do live checksum comparisons.
No problem at all for the old cossies.
Old Mar 2, 2005 | 07:42 PM
lancia delta 6 times WRC's Avatar
These guys market one for the grale which uses a very similar ecu, i cant believe you cossie boys havent got this already as your so well catered for.
http://www.evocars.com/acatalog/EPROM_Lancia.html
Old Mar 2, 2005 | 07:43 PM
Stu @ M Developments,
I did say only the select few can do this and you are definitely among them
Old Mar 2, 2005 | 07:44 PM
Wouldnt even know where to start with the one you just mentioned though Simon
Old Mar 2, 2005 | 07:53 PM
Mark Shead's Avatar
Mark Shead
You can do a offset map with SM4 for race fuel,Or Carry a laptop and you can have 100maps
Mark
Old Mar 2, 2005 | 07:56 PM
GARETH T's Avatar
GARETH T
Moose 130,
mark,,,, ahhh hummm
Old Mar 2, 2005 | 08:22 PM
markk's Avatar
markk
lancia delta 6 times WRC,
ive had dual maps inmy car for about a year or so now
would be able to demo it for the purposes of this topic for genuine MSD customers
Old Mar 3, 2005 | 07:23 AM
foreigneRS's Avatar
foreigneRS
Testing the future
very interesting, didn't know that it was possible on the marelli ecu. you is some clever people
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
jay030787
Sep 25, 2015 01:38 AM
