Help Plz '88' Escort RST possible overfuelling not sure
Old Jun 16, 2012 | 12:35 AM
kevb1979's Avatar
kevb1979
Default Help Plz '88' Escort RST possible overfuelling not sure
Hi there been a while since i have been on here but hopefully some of you will possibly be able to help me
First of all the car is my wife's 1988 Escort Rs Turbo it has been off the road for the last 2 year's with a broken turbo but has been started regually apart from the last year as her dad had taken the turbo off for us to replace it before the turbo was removed the car had no problems starting at all
Now for the puzzling bit
After replacing the turbo priming it with new oil replaced oil and filter i was ready to start the car up for sum reason it wouldnt start and seemed to be flooding all the time as it wasnt even attempting to fire after taking the spark plugs out to find them soaking wet i checked for a spark which was a good one refitted the plugs and still had the same problem after many attempts with out it starting it did eventually fire up but was chucking what i thought was oil back out of the dipstick which i later realized was fuel and the tennas worth of fuel i had just put in the tank had totally gone with the car only starting once i wiped off the dipstick and the level was right up the stick and stinking of fuel so i drained the oil which was now pure pertol with a bit of oil in it drained it all out and started again this has now done this three times
during all this though i removed the spark plugs and cranked the engine with the fuel pump running at first there was a fine spray of fuel cuming out of the spark plug holes then after 2 or three cranks the fuel was spraying out of the plug holes as if there was sumbody chucking buckets of fuel out of the cylinders
so removing the fuel pump fuse and cranking the engine over until there was nothing cumming out of the plug holes i replaced the spark plugs and leads with new ones leaving the fuse out i could get the car to start and it would run on tick over with out the fuse in which i am surmising it was running with the fuel that was in the oil it did this for about 5-10 mins before cutting out
now i can get the car to start without the fuel pump fuse in and as soon as a replace the fuse the engine cuts out and the spark plugs are soaking wet again does anybody have any ideas what could be causing this as its totally got me and a few others baffled i am a mechanic myself but carnt understand why its doing this unless the metering unit is playing up but carnt understand that before the turbo was removed there was no problems with this and the only thing that has been touched is the turbo
Hope somebody out there can help
CheeRS in advance
Kevin
Old Jun 16, 2012 | 11:29 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Kevin try unplugging the sensor on the right hand side of the fuel metering unit and try again. It sounds like it is faulty. ?
Old Jun 16, 2012 | 11:38 AM
phil_rs's Avatar
phil_rs
yam yammer
It could very well be the coolant temp sensor which is the yellow one that fits in the injector sandwich plate. When mine went it would run but hardly rev up and was chucking out loads of black smoke
JK12
33
Apr 26, 2021 12:09 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Billy_RS
Sep 13, 2015 04:17 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
