Mk1 rs re-circ valve
Old Jun 15, 2012 | 02:57 PM
RSargie's Avatar
RSargie
Default Mk1 rs re-circ valve
Hi, just a quick'y I had the intact system apart the other day and forgot which way round the standard Bosch re-circ valve goes. Logic tels me that the pressure side is directly opposit the were the vac pipe goes. Bit like an aftermarket bailey or forge. But I think I may be wrong so could some one please confirm the correct way or post us a pic.
Thanks
Rich
Old Jun 15, 2012 | 03:24 PM
pee vee's Avatar
pee vee
the side opposite the vac hose goes into the inlet pipe, on the turbo.
the other pipe at 90 degrees to it snakes around a bit then joins to the intercooler..
Old Jun 17, 2012 | 08:00 AM
RSargie's Avatar
RSargie
That's great, thanks
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
fordrallycar
Sep 30, 2015 07:57 PM
Tank Mike
Sep 26, 2015 08:07 AM
