UPDATED need help problem with clutch or gearbox
it drive fine only when you got to take off you can hear screaching and cluterring from the gearbox end was just thinking it sounds as if the clutch bearing is fcuked but the noise is only ther when your just coming off the bitting point as you go to move off it happens in all gear so help is it gear only on the bitting point off all gears other wise drive normall box or clutch
NORTH YORKS RS SPARES, thats what i thought would you have a clutch kit for a cossy and upgrade from std as iam runnig 354bhp even second hand padel would do thanks
JK12
33
Apr 26, 2021 12:09 PM
