Wheels and Tyres Wheels and Tyres for all Ford's
Tyre help
Old Jun 13, 2012 | 09:18 PM
Rsmat's Avatar
Rsmat
Default Tyre help
What size tyres for my 3dr lowered 20mm for 17x8 TSW Hocks.... Without cutting arch kit..!...?
And name me a good tyre to fit... Car is only used in dry.
Many thanks Mat.
Old Jun 13, 2012 | 09:37 PM
martysmartie's Avatar
martysmartie
Not much help, but I think you are limited, IIRC around 235 is the maximum size you can have.
Martin
Old Jun 13, 2012 | 09:41 PM
botters's Avatar
botters
competant bodger
dont think you can get 235 under standard arches mate i could be wrong tho
Old Jun 13, 2012 | 09:54 PM
Rsmat's Avatar
Rsmat
I'm waiting for ADE500 ad I'm sure he as same as I want... I'm sure he runs 235 rear.
Old Jun 13, 2012 | 10:04 PM
Tarren's Avatar
Tarren
Alot depends on the offset of the hocks mate, ie how low or high is the ET
Old Jun 13, 2012 | 10:06 PM
Ade500's Avatar
Ade500
Fixing Fords
Yep I have Goodyear 235s on the rear and no they won't fit without trimming. Its the camber shims they put them out about 20mm more. A 215 may be ok though.
The dia of the 235 is alot larger it's not just the width that puts the rears right up to the front of the arch. I could try a front which is a 215 on the rear and see how close it is if you like?
Old Jun 13, 2012 | 10:07 PM
Rsmat's Avatar
Rsmat
Cheers ADE your a diamond that would be great if you could please..
Old Jun 13, 2012 | 10:08 PM
Ade500's Avatar
Ade500
Fixing Fords
Mine are et 40 I think your are to aren't they ?
Old Jun 13, 2012 | 10:12 PM
fraser9764's Avatar
fraser9764
i think most hocks are et40
Old Jun 13, 2012 | 10:13 PM
Rsmat's Avatar
Rsmat
Yes mate et40
Old Jun 14, 2012 | 11:47 AM
Rsmat's Avatar
Rsmat
Anyone else...?
Old Jun 14, 2012 | 01:38 PM
mark r's Avatar
mark r
im using falken 452, 235 40 17 on 8j but there are a few 235 35 out there as well
mark
Old Jun 14, 2012 | 02:15 PM
JamesH's Avatar
JamesH
You won't go wrong with Goodyear Eagle F1's of any kind, preferably GSD3's (if you can still get them?), or assymetrics
Old Jun 14, 2012 | 04:04 PM
Rsmat's Avatar
Rsmat
Cheers guys...
Old Jun 14, 2012 | 04:53 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Eagle F1's have always impressed me, I've had are other tyres that do a same/similar job in the dry... but the F1's performance in the wet is outstanding IMO.
Cheers,
Grant
Old Jun 14, 2012 | 04:57 PM
Rsmat's Avatar
Rsmat
I've got F1's on the standard rims and they have been very good.
Old Jun 14, 2012 | 05:12 PM
WongRS's Avatar
WongRS
i'd go for 215-40-17 or maybe a 225-35-17 Mat, Can't go far wrong with Michelin PS, but you'll pay for them, believe it or not, Kumho are a very capable tyre for the money.
Old Jun 14, 2012 | 05:24 PM
Rsmat's Avatar
Rsmat
Cheers mate will take a look at both.
Old Jun 14, 2012 | 05:29 PM
WongRS's Avatar
WongRS
I'll see if i can price some up tomorrow if i remember, will text you if i do.
Old Jun 14, 2012 | 05:41 PM
Rsmat's Avatar
Rsmat
Yea cheers mate...
Old Jun 14, 2012 | 05:56 PM
BRAMMER's Avatar
BRAMMER
I would say your limited to 215 mate due to the width of the wheel and the shims fitted straightening the wheel in the arch - you may even get a little rubbing at hard acceleration though
Old Jun 14, 2012 | 07:07 PM
Rsmat's Avatar
Rsmat
I will have to try mate hope not..!
Old Jun 14, 2012 | 08:47 PM
Harris.'s Avatar
Harris.
On the front of mine i have 205's and the rears are 217 .
Front wheels are 7j et30 and the rears are 8 j et30 .
Mine will be fitted with new rear springs in the next week , they wont catch the arches .
Tyre choice ,ive always used yokahama parada spec 2 ,they are excellent when warm but arse twitchie in the wet .
Old Jun 14, 2012 | 08:59 PM
RONNIE AMIS's Avatar
RONNIE AMIS
cant help with offset or anything but i always rate toyo t1r's for a road tyre
Old Jun 14, 2012 | 09:02 PM
Rsmat's Avatar
Rsmat
Yours is standard ride height tho mate..
Old Jun 14, 2012 | 09:03 PM
Rsmat's Avatar
Rsmat
Agree Ronnie but I've only ever used them on a fwd car... Are they still good on rwd..?
Old Jun 14, 2012 | 09:04 PM
RONNIE AMIS
had them on my saph road car and i was really impressed
Old Jun 14, 2012 | 09:07 PM
Harris.'s Avatar
Harris.
With a drop of 20mm mine still wont catch mate , the rear end will be a little stiffer /solid so it will be fine .
Old Jun 14, 2012 | 09:14 PM
Rsmat's Avatar
Rsmat
Ah right another option then... Cheers mate....
So is your lowered 20mm and on camber shims same as mine...?
My spec
Lowered 20mm on Ahmed bajoo springs
Camber shims
MSD diff mount
Rear end fully poly bushed.
Old Jun 14, 2012 | 09:26 PM
Harris.'s Avatar
Harris.
My spec
Camber shims
MSD diff mount
Mine has MSD diff mount
rear arb polybushed
and will be using the same springs , just remember my wheels are et30 yours are 40 . How thick are your shims? I also have koni shocks set on soft which i will set to half way once the above bits are fitted .
Old Jun 14, 2012 | 09:32 PM
Rsmat's Avatar
Rsmat
Not sure what the shims was now.... I'm on koni fronts and bilstien rears has that's supposed to be the best set up.
Old Jun 14, 2012 | 09:42 PM
Harris.'s Avatar
Harris.
If your shims are say 10mm thick then your alloy offset would be the same as et30 so a 215 tyre would be best on the car .
See the above pic i have a fair amount of room above the rear tyre,infact the car looks jacked up .That pic was taken before the diff mount and bushes were fitted .
Old Jun 14, 2012 | 09:48 PM
Rsmat's Avatar
Rsmat
Hope your right mate..
Old Jun 14, 2012 | 09:50 PM
Harris.'s Avatar
Harris.
Also are your hocks 7j 7 1/2 j or 8j ??
Old Jun 14, 2012 | 09:57 PM
Rsmat's Avatar
Rsmat
There 8j mate
Old Jun 14, 2012 | 10:03 PM
Harris.'s Avatar
Harris.
In that case then mate i think your rears will be fine as ive said above .
But you will need to have them front arches rolled as the 3 door bodykit over hangs the arches on the front by around 5mm .When i had 8j all round they caught the front so it was either have the wheels machined or get new ones hence why i now have my 7th set of wheels on the 3 door
Old Jun 14, 2012 | 10:11 PM
Harris.'s Avatar
Harris.
EDIT!!! Just seen adde500 mention them shims are 20 mm , They would take the alloys to near escort cosworth offset which are et25 and arch catch on 3 doors all round . Im sure i had 205s all round on my ecos alloys.
Sorry to keep changing ,but them shims make a hell of a difference .
Dave
Old Jun 14, 2012 | 10:56 PM
Rsmat's Avatar
Rsmat
Jesus... Fuck knows what I'm going to do here now I'm confused....
I'm deffo not cutting the kit..!
Old Jun 15, 2012 | 06:02 AM
Harris.'s Avatar
Harris.
Im awake now
ET40 8j with a 215 tyre on the rear wth all your added bits ie diff mount,shocks etc will be fine . You should find the rear end dont squat .
When i fitted 17x8 revoloutions with 205's on my 3 door they lasted around 10 miles then i took them off as they just wreaked the arches .So really you have 3 options
1) trim the arches back and you may also have to trim the edge of the front bumper as mine also caught that, a pro would get it looking spot on ,or maybe you could fit another arch kit and keep yours safe ??
2)Have your front wheels machined to a different offset .
3)Remove the shims if there 20mm which would give you a little more room in the front arch
I spent hours on the phone to comp working out with them a nice size and looking wheel for the 3 door .These cars without cutting and messing about are hard to get a nice wheel on in 17/18 .Need anymore advice pm me your number and i will call you
Dave
Old Jun 15, 2012 | 06:14 AM
Harris.'s Avatar
Harris.
When i had the ecos wheels, ET25 . Hit arches with 205's
comp 17 Et37 71/2 j ,These were spot on
Old style comp s,these were ET35 17 s by 7 1/7 j and were fine
And now i have 17x8 rear Et 30. 17x7 Et 30 front which are fine,but had to take a few mm off the kit/bumper
