Dumpvalves leaking at full boost
Old Mar 2, 2005 | 03:34 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default Dumpvalves leaking at full boost
Do they often? On big boost cars?
Ive heard of it many times (TBH i think its why racers rarely use em).
The boost pressure overcoming spring pressure and lifting the valves from their seat slightly on full boost? Even if it dont do it enough to lose boost the turbo will overspeed to compensate, causing more heat, less efficiency, less power, and maybe killing turbo quicker.
I can imagine it even with a strong spring, as the assistance the pressure fed down the vac pipe to assist the spring isnt much.
I dont want to fit DVs on my car, but bearing in mind the huuuuge size of the turbo and the fact im most likely running 2-2.5bar full boost (turbo is a mega efficency job thats able to run silly pressure without heating the air badly), im worried il break summat without em
Got 2x Shiney Forge Diaghpram ones with the Cosworth strength spring in it. Anyone know if theyl be ok? I could put even harder springs in em from the forge piston ones made for jap cars with AFMs i guess
Thing is i bet 99% of people whos dumpvalves open slightly at full boost dont realise anyhow, as TBH youd only really see it on a rolling road and only then if you was watching for it.
Advice/Info appreciated, esp from peeps like Martin H, Stu, Sheady, etc, whos probably came across this prob 100s of times...
Old Mar 2, 2005 | 03:46 PM
COSWORTHFORDS's Avatar
COSWORTHFORDS
I know of somone with a race car that runs a 580bhp cosworth engine and he has a piston dump valve with no problems.......!!!!
Old Mar 2, 2005 | 03:56 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
But does it lift off the seat at all? I doubt he knows, youd almost deffo never notice while driving.
Old Mar 2, 2005 | 04:15 PM
cossymad's Avatar
cossymad
We had this a few times on scoobies but not on high boost all the time, but usually at 100+ mph
Don't know why, but we fitted larger springs whcih solved the problem.
I reckon you'd blow a diaphram to pieces as even the best Neotech or kevlar ones split at 30+psi
Old Mar 2, 2005 | 04:20 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I would personally stick with the Bailey piston ones to avoid the problems relating to split diaphrams (which can cause amongst other things an unwanted pregnancy).
As you rightly point out, you would only notice this happening on a rolling road. Otherwise the turbo will compensate as mentioned.
Old Mar 2, 2005 | 04:28 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Well Forge do really really good Piston ones that blatantly would flow more than the pissy bailey ones, and also they do ones with a bigger (about double) diameter inlet so they fit on S14 200SXs etc.
These are brand new, still in bubblewrap, i wonder if theyl do some kind of trade-in, they are nice folk down Forge
You think that diagphrams will split at 30-35psi boost? Thought theydve made em better than that
Old Mar 2, 2005 | 04:29 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
So whats the deal with them lifting then? Just put in the strongest goddamn spring ever, or they be ok? Overspeeding it will take it out of its efficency, wouldnt it?
Old Mar 2, 2005 | 04:32 PM
Mike Rainbird
Caraholic
Yes, but if you had an ACT gauge and an EGT, you would soon get a feel for what is normal and what isn't .
GARETH T's Avatar
GARETH T
cant see it happening myself,,,
the differantial pressure on the spring side is always the greatest
force =pressurexarea
the spring side has an larger area and spring pressure
the other side has a smaller area and no sping
Old Mar 2, 2005 | 04:37 PM
Mike Rainbird
Caraholic
Gareth,
In my experience, sometimes they stick open / half open.
Old Mar 2, 2005 | 04:44 PM
Rhys's Avatar
Rhys
What do you call big boost for this to happen?
How do Spec-r D/V rate too?
Stavros's Avatar
Stavros
DEYTUKURJERBS
That sounds like a sales pitch to me
Dont worry, there a fair few bits n pieces il be buying off you actually...
Gareth- Good point
Old Mar 2, 2005 | 04:46 PM
GARETH T's Avatar
GARETH T
Mike Rainbird, my motto is
"look after your dump valve,,, and it'll look after you"
Old Mar 2, 2005 | 04:47 PM
cossymad's Avatar
cossymad
We get loads...well did.....of split diaphrams back.
We found the scooby ones (bailey) opening up on motorway and you could actually hear them leaking!!!
Old Mar 2, 2005 | 04:53 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
on some dumpvalves, you can make them stay half open and whistle if you get the throttle just right, which indicates to me that the spring is weak, I got a forge one on my cos at the moment, and it dosn't dump untill 10psi, so I assume it has a far stronger spring.
Old Mar 2, 2005 | 04:57 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
I can get diagphrams for owt and i used to always check mine every week or so anyhow when i ran em, so thats not bothering me much.
Its that lifting thing that worried me.
In all honesty id much prefer to run no DVs, and im soo unconvinced they do anything worthwhile, but would YOU want to risk a top technology fancy as fuck huge turbo running 2bar+?
I was gonna risk it, but im getting scared
Old Mar 2, 2005 | 05:01 PM
St3V3_C's Avatar
St3V3_C
I think that has more to do with the fact that you have a lower pressure from throttle plate to engine than you do from turbo to throttle plate
I can get mine to do it for short periods (usually on a slight uphill) and have actually checked it on the RR, it was not leaking at full chat. Only 20-something psi though.
Old Mar 2, 2005 | 05:03 PM
Big Andy W's Avatar
Big Andy W
The pressure will be the same on both sides i'm sure as pressure is uniform ie the same everwhere!
Surely you can't have 32 psi in one place then 22 some where else in the same system, unless you have a regulater!
The spring is there to increase the force on the diaphram to push it closed and over come the identical pressure on both sides of the diaphram!
I've been running the same GGR dump valve(with kevlar composite diaphram) and it ain't never split in 4 years!
Old Mar 2, 2005 | 05:22 PM
GARETH T's Avatar
GARETH T
pressure might be the same,, but the area if different so the force is
Old Mar 3, 2005 | 12:41 PM
NathR's Avatar
NathR
Could this happen on a standard Bosch re-circ through a cone filter?? I occasionally get a strange whistling noise when on boost?!
Old Mar 3, 2005 | 12:48 PM
Mike Rainbird
Caraholic
Nath,
That's probably your piddly little turbo blades going supersonic .
Old Mar 3, 2005 | 12:51 PM
NathR's Avatar
NathR
Nath,
More than likely
*cough*TWAT
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
