pectel t2 help
Old Jun 8, 2012 | 05:11 PM
lukefrs's Avatar
lukefrs
Default pectel t2 help
hi guys
im in the proccess of trying to purchase petel t2 but im a tad confused.
when i spoke to cosworth electronics theyve said that i need to state what options i need.theyve said that theres 3 outputs that are spare.
iv spoken to a few distributers and some recognise this and some dont???
the ones that do dont feel they can advise me on what options to pick
im in a real pickle here as im no good with this side of things.
dont know if you need to know this but its going into a mk1 focus rs that hasnt got a single wire left in it,the whole car is being rewired.
other things will be...
-AIM dash
-blitz controler
-standard injectors
-bosch 044 pump
again not sure if this info is needed.
can anyone advise me aon what options i need to run the car????
any help atal will be great
Old Jun 8, 2012 | 05:34 PM
Gav Diamond's Avatar
Gav Diamond
Ring Harvey Gibbs at SCS (01733 576 614), he will help you out as he sells these.
Old Jun 8, 2012 | 05:47 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
The 3 spare outputs can do:
Boost contol
Cooling fans
Fuel pump
Tacho.
As you can see you really need 4 spare outputs, this is where T2 falls down. You could switch the fuel pump by using a relay from an XR4x4 (purple one) and that would then leave you with three.
Old Jun 8, 2012 | 05:58 PM
lukefrs's Avatar
lukefrs
just emailed harvey
thanks for reply martin.so youd recommend having the other 3 and having a seprate way to power fuel pump??
is it correct that all this has to be in the spec when ordering the t2??
ed at cosworth tells me soldering has to be done etc???
thanks again
Old Jun 8, 2012 | 06:03 PM
Martin-Hadland
Originally Posted by lukefrs
just emailed harvey
thanks again
Yes to all that.
Old Jun 8, 2012 | 06:23 PM
lukefrs's Avatar
lukefrs
With having the aim dash will I need the tacho output???
Old Jun 8, 2012 | 06:30 PM
Martin-Hadland
No you wont, so there you go ... Sorted.
Old Jun 8, 2012 | 06:33 PM
lukefrs's Avatar
lukefrs
3 simple replys from you Martin and all sorted.thanks a lot mate.very greatful
Old Jun 8, 2012 | 06:37 PM
lukefrs's Avatar
lukefrs
With the t2 running boost,does that mean no need for blitz spec r???
Old Jun 8, 2012 | 06:48 PM
Martin-Hadland
Correct, the ecu can control the boost solenoid (air injectors if you wish) or you can externally control it with your Blitz contoller. I'd use the ecu to contol boost.
Old Jun 8, 2012 | 06:54 PM
lukefrs's Avatar
lukefrs
Martin your a star mate.thanks
Old Jun 9, 2012 | 08:52 AM
markk's Avatar
markk
how much are these ecu's now?
Old Jun 11, 2012 | 10:53 AM
lukefrs's Avatar
lukefrs
650 plus vat is best I can find.
Pectel are making the final batch now.that's it for the t2 then.
DixieTheKid
11
Jun 6, 2020 11:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
jay030787
Sep 25, 2015 01:38 AM
Steve Cooper
Sep 15, 2015 04:39 PM
muz
Aug 16, 2015 12:57 PM
