Nice spec zetec turbo block *price dropped*
Old Jun 7, 2012 | 11:23 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Default Nice spec zetec turbo block *price dropped*
hi all.
i have for sale a blacktop zetec turbo block which has had a fair bit of machining done. for starters it has the larger silver top main caps fitted, which have been line bored and honed to suit this block. it has been rebored and honed to 86mm with the intention of fitting vauxhall pistons, but will suit a lot of other pistons as they seem to make a lot that size. it has been faced with a surface finish more than adequate for a cometic gasket or similar. it also has an m12 head bolt conversion, ready for big power!
Also, it comes with a balanced ST170 crank and refaced 2.0 mondeo flywheel. the crank is fitted with brand new glyco mains.
i also have a set of vauxhall XE pressure cast pistons on zetec rods, ready to be fitted with ACL bearings.
I'm looking for around £400 for all of this, pics to follow soon. i may consider splitting if i get the right offer.
Old Jun 10, 2012 | 11:29 PM
Turbo Zetec
Engine Machinist
some pics:
there will also be a sump and oil pump included
Old Jun 11, 2012 | 07:42 PM
Windy RST's Avatar
Windy RST
this is exactly what i'm after but no dollars in the bank!!!
GLWTS
Old Jun 12, 2012 | 05:44 AM
Gadget's Avatar
Gadget
Spanner monkey
Is this rear mounted starter position?
Old Jun 12, 2012 | 05:07 PM
Turbo Zetec
Engine Machinist
hi, its either, as it uses the silver top sump due to the larger main arrangement
Old Jun 16, 2012 | 12:40 PM
Windy RST's Avatar
Windy RST
pm sent.
Old Jun 17, 2012 | 12:47 AM
davidfox280585's Avatar
davidfox280585
would you split the acl rod shells?
if so what size are they?
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
