4x4 and 2wd sump
Old Jun 7, 2012 | 10:40 PM
tomoyb's Avatar
tomoyb
Default 4x4 and 2wd sump
is it safe to assume you cant remove a 4x4 cos front diff and leave sump in place to run 2wd
without a mojor spill?
Old Jun 7, 2012 | 11:08 PM
markk's Avatar
markk
you wont get any oil at all unless you have an internal leak, there is no cross contamination between engine oil and diff oil
Old Jun 8, 2012 | 09:18 AM
tomoyb's Avatar
tomoyb
So can the 4x4 sump stay in place?
What about the through shaft?
Old Jun 8, 2012 | 09:41 AM
M88RT J's Avatar
M88RT J
i used my 4x4 sump when i converted mine to rwd, just welded it up where i removed the through shaft
Old Jun 8, 2012 | 11:09 AM
M K's Avatar
M K
No reason to warrant welding up the hole where the cross shaft goes, looks neater though,
Just remove the shaft and put a rubber bung in each end to stop getting crap in the speedo drive housing and bearings, or if you don't use the either then remove housing/speedo drive and bearings as well
Old Jun 8, 2012 | 01:33 PM
M88RT J's Avatar
M88RT J
thats the only reason i did it mate
Old Jun 8, 2012 | 03:49 PM
tomoyb's Avatar
tomoyb
what bearings mate?
Old Jun 8, 2012 | 03:50 PM
tomoyb's Avatar
tomoyb
if running t5 box wouldnt that have its own speedo drive?
Old Jun 8, 2012 | 06:07 PM
COLEYST200's Avatar
COLEYST200
T5 has its own speedo drive . There is a lad in brum with a escort Cosworth which was 4x4 but now 2wd all he did was take the drive shafts out tuck the insides of the CV out removed the frount prop and just bolted the T5 box on and it's been like that for over 2 years now
155lee
Oct 27, 2015 04:55 AM
mark r
Sep 29, 2015 07:27 PM
IainRS1700T
Sep 25, 2015 06:44 AM
little bram
Sep 21, 2015 02:50 PM
BRAM
Sep 8, 2015 07:11 AM
