General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Wicked i hav a fiesta rs turbo and its running 15 psi on blue injectors and a superchip every1 i speak to says it ain't possible so i'm thinking i might hav cosworth blues ?????
You could i suppose but it would be running lean i would expect at 15psi with fiesta ones.
I am not sure how you would go about running them as iirc fiesta injectors run around 15 Ohmz and cossie are less than 5 Ohmz so not sure how that would effect them.
The person i brought my rs off was running 180bhp @ 10psi and has done sum cossie bit for sum reason cossie amal valve i think he might of found a way lol
As a few people have suggested cossie injectors will not work on fiesta management unless you are a clever cookie and alter the impedance using resistors. Don't quote me on the using resistors as I am not too clued up with electronics but the impedance will have to be changed somehow because they are of totallly different values. A fiesta uses high impedance 16 ohm and cossies are 5 or 6
Turn the boost down asap as you are on borrowed time and the injectors will be working their tits off. Pretty sure you shouldn't run them over 80% duty cycle.
as far as i know standard i will be fitting a sytec 300bhp soon as i can and an omex management system green injectors 3 bar map sensor and a sytec pressure regulator then she will b ready for the rollers
thanks for the advice Oranoco she is off the road at the min goin to fully underseal her put new sills in and wax oil all the inna sill and get her shell 110% safe the be sortin the fueling and management issues i hav lol thanks tho
