Actuator tubing what do you use?
Old Jun 6, 2012 | 05:52 PM
Ridgey's Avatar
Ridgey
Default Actuator tubing what do you use?
Just wondering what tubing people use between the compressor housing, amal and actuator.
I have been using silicone tubing for years on a T3 turbo but wonder if this is up to the job for pressures approaching 30psi on a T34 ?
Old Jun 6, 2012 | 06:12 PM
rog's Avatar
rog
I used rubber fuel injection pipe I bought from Halfords running a t4 +20psi, tbh your tubing should be ok I'd think.
Old Jun 6, 2012 | 08:01 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
silicone hose will be fine, i've had a couple of BAR through the stuff for a while on an older engine spec without failure.
Old Jun 6, 2012 | 08:07 PM
nevsrevs's Avatar
nevsrevs
fuel hose for us,
Old Jun 6, 2012 | 08:13 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I still have silicone hose on mine, but the Moan always Moans about it
Steve
Old Jun 6, 2012 | 08:21 PM
rs2klee's Avatar
rs2klee
K***LMT
3mm silicone pipe on mine works ok on T34, just put some small 3mm cable ties on at each end, had no trouble at all!
Old Jun 6, 2012 | 08:40 PM
stevieturbo's Avatar
stevieturbo
C**t
Rubber hose, wouldnt put that shite silicone near important pipes like that
Old Jun 6, 2012 | 08:44 PM
JamesH's Avatar
JamesH
I always just used fuel hose
Old Jun 6, 2012 | 08:53 PM
fraser9764's Avatar
fraser9764
+1
https://passionford.com/forum/ford-e...re-to-buy.html
Old Jun 6, 2012 | 09:03 PM
Ridgey's Avatar
Ridgey
Fuel hose it will be then i recon, about 7mm probably to get it on the amal valve pipes.
I probably had 3mm silicone hose as it is so stretchy
Old Jun 6, 2012 | 09:27 PM
Brendan's Avatar
Brendan
struggling with reality
just make sure it is held tight at the ends as you don't want it popping off!
Old Jun 6, 2012 | 09:31 PM
stevieturbo
C**t
If it's good quality hose and a size smaller...ie 6mm instead of 8mm, then usually no clips are required.
But it if there are no barbs at all then clips of some kind should be considered essential
Again, a lot will depend on the quality of hose and nature of hose end/barb etc.
Old Jun 7, 2012 | 07:53 AM
rog's Avatar
rog
Personally I have put on small jubilee style clamps, it finishes it off, I'm not a bufty in that sense I just wanted it to look factory and well built and you definately won't have to worry about it coming off either, so it's a no brainer IMO.
Old Jun 7, 2012 | 09:32 AM
stevieturbo
C**t
As with silicone....I would never use jubilee style worm drive clamps on any small diameter hose. They do not clamp round.
Always use the correct clamp for any given hose size.
Old Jun 7, 2012 | 11:48 AM
opposite lock's Avatar
opposite lock
Rubber piping all the way. I think the blue silicone looks amateur and tacky too.
Old Jun 7, 2012 | 01:41 PM
paul16v's Avatar
paul16v
Monte 087
As said rubber fuel hose or diesel leak off pipe looks miles better than silicone.
Old Jun 7, 2012 | 05:37 PM
nevsrevs's Avatar
nevsrevs
we use fuel clips on our pipe as said above they clamp all the way round,
Old Jun 7, 2012 | 07:30 PM
Ridgey's Avatar
Ridgey
Petrol pipe clips just got some.
Old Jun 7, 2012 | 07:44 PM
Jim Galbally's Avatar
Jim Galbally
silicon hose gets brittle when it gets hot, not good for turbos!
just good old fasioned rubber vaccum hose does the job perfectly.
Old Jun 7, 2012 | 09:34 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i've never had any issues with 3mm silicone vac hose for actuator/wastegate, never split or gone brittle, admittedly i change the spec and hoses every year so no time to fail really.
Old Jun 8, 2012 | 12:02 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
depends on the silicone hose you use. There are some proper silicone hoses used in vacuum processing at temperature such as with pre-preg carbon fibre production that can handle both the temperature and the pressures necessary. The stuff i got has a much thicker wall than the usual silicone hose used for vac lines on cars.
Oranoco
12
Oct 2, 2015 02:18 PM
Fudgey
21
Sep 30, 2015 06:19 PM
A.t.p
Sep 29, 2015 05:04 PM
CrOwSoN15
Sep 10, 2015 07:33 PM
