oil pick up pipe cvh
Old May 29, 2012 | 03:52 PM
Marc D's Avatar
Marc D
Default oil pick up pipe cvh
was stripping down my 1900 cvh bottom end and found one of the bolts holding the oil pick up pipe was rounded slightly (the allen key headed bolts) and after trying several things its alot worse. anyone know how im best removing the bolt?
cheers
Old May 29, 2012 | 03:58 PM
haz87's Avatar
haz87
You can *just* get a set of mole grips round them. Should be enough tbh as they are pretty hard to do up overly tight
Old May 29, 2012 | 04:19 PM
Rob_DOHC's Avatar
Rob_DOHC
If that doesn't work, Get a dremel/hack saw and cut a slot for a big flat headed screwdriver. Just give it a few taps before you undo it, this normally loosens the threads up a bit.
Rob,
Old May 29, 2012 | 04:29 PM
Marc D's Avatar
Marc D
ok thanks alot guys. ill see if i can find a decent pair of mole grips
JK12
33
Apr 26, 2021 12:09 PM
Ian1964
12
Jan 26, 2021 11:57 AM
TPM961
Jan 15, 2018 10:50 AM
RSmark84
Sep 13, 2015 01:29 PM
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
