Hydraulic handbrake
Old May 26, 2012 | 08:22 PM
pieterjan's Avatar
pieterjan
Default Hydraulic handbrake
I have fitted an hydraulic handbrake on my sierra cosworth i've used braided hose and fittings but i can't get the handbrake right. It works a little bit and i've bleeded the car 4 times and there is no air in the systeem. Is there a special way to do this?
Old May 26, 2012 | 08:57 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Perhaps the master cylinder on the handbrake itself isn't big enough and not giving enough movement on the calliper pistons to fully apply the brakes.
Old May 26, 2012 | 09:33 PM
William MK2 Cosworth's Avatar
which way have you put the hoses on the handbrake?
first time I put mine in, it wouldn;t brake at all, just pust the brake pedal up if I had it pressed, and thats how I found out it was not connected right!!
Old May 27, 2012 | 08:16 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
as said, if you connect them wrong obviously they wont work.
the feed goes into the rear fitting and the pressure side goes to to the rear brakes HTH
Old May 27, 2012 | 08:42 AM
pieterjan's Avatar
pieterjan
I've put the connections like on the picture and it's the same handbrake. The master cilinder is 0.625 so i think it's good. It goes but only at the end. If you out your foot a little bit on the brake pedal the handbrake is perfect!
Old May 27, 2012 | 09:12 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
air trapped in the handbrake cylinder
it's a bummer to get out
we used to remove the piston circlip and let piston out a bit till the seal is revealed and push the seal down a little bit to let the air out
Old May 27, 2012 | 10:04 AM
zippyobrien's Avatar
zippyobrien
Back bleed it other wise.
Old May 27, 2012 | 11:26 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
can you get access to a vaccum bleeder?
the best bit of kit i have bought.
you run them off an air compressor. thats how i done mine and the handbrake was amazing.
Old May 27, 2012 | 11:37 AM
pieterjan's Avatar
pieterjan
We had a rally car back in the days and it was an realy nightmare to get it out but i don't know how we did it then i think i was to young then lol! I will try your way tommorow.
pieterjan's Avatar
pieterjan
What type of bleeder do you have?
Old May 27, 2012 | 12:17 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Its a sealey one like this mate
you connect an air line to it, and it sucks the fluid and air through
Old May 27, 2012 | 12:19 PM
pieterjan's Avatar
pieterjan
I saw them on ebay. I will buy one if i don't get it bleeded on the normal way. Thanks!!!
Old May 27, 2012 | 12:27 PM
Mr C's Avatar
Mr C
I had the same, I eventually bled it using the hand brake lever, bleed the nipple, release, handbrake on, bleed,release for ages and on both sides and then with the foot brakes, urgh! A vacuum bleeder as above would have sucked it out a treat though
Old May 27, 2012 | 02:07 PM
blue oval 24v's Avatar
blue oval 24v
jack the rear off the car up as high as you can and bleed again
Old May 27, 2012 | 05:52 PM
markk's Avatar
markk
I wonder who told you about them mate
Old May 27, 2012 | 07:11 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
exactly mate! golden advice!!!
if only i had bought one fooking years ago lol.
that and an SDS hammer drill lol... live and learn eh!
Old May 27, 2012 | 07:20 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
They are a royal pain to bleed I have a group N Civic sitting two weeks because I just can not be bagged getting it bleed.
Old May 27, 2012 | 08:18 PM
markk's Avatar
markk
too true, an old saying, 'you can't buy experiance'
Old May 28, 2012 | 08:07 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
that is true mate, and im glad there people about like you, to share theirs!!
Old May 28, 2012 | 06:51 PM
fanny's Avatar
fanny
could be air trapped in calipers turn calipers upside down use block of wood to act as a brake disc between pads and re-bleed
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
hopper350
Sep 4, 2015 12:53 AM
