Megasquirt Help
When you set up the project in the first place it generates a base map, that's all you need to get started. Unless your using the exact same spec as someone else it's going to be miles off. Even the same spec would need adjustments.
check out our mapping site, www.mtechmaps.com there are a couple of maps that may get you closer, but as Rhino says, please get them checked over by a profesional tuner before putting the engine under any load, as damage can occur...
We fully map for £250+VAT on our dyno dynamics rolling road.
Matt
Matt
1.8 esc
11
Jun 22, 2006 12:48 PM
