Electrics/ light problem. Need help!
Old May 24, 2012 | 09:45 AM
MrLjdude's Avatar
MrLjdude
Question Electrics/ light problem. Need help!
Hi all
I drive a MK1 (2001) Ford focus 1.4. pretty soon an MOT is due and I have just discovered my reverse light does not work.
(its not the bulb, I already checked that)
Does anyone know what the problem might be and how to fix it.
(please give clear and good instructions)
Thanks guys and gals.
Old May 24, 2012 | 09:57 AM
B19 JUB's Avatar
B19 JUB
reverse light isnt tested on an mot fella so no worries about it failing.regards to not working could be the bulb not working.worth a try first.more than likely reverse light switch
Old May 24, 2012 | 12:07 PM
martysmartie's Avatar
martysmartie
Is it not a case of where fitted it should be working though?
as to the problem most likely the switch or connection problem, seen as you have eliminated the bulb.
Martin
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
The Enigma
Sep 12, 2015 10:12 PM
