BEEFYS S1 rwd cossie shell - for sale folks
Old May 23, 2012 | 07:25 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
Default BEEFYS S1 rwd cossie shell - for sale folks
ok folks here goes ,
please rear the entire advert before commenting , all serious enquirys should contact me @ 07787354837 ,
PLEASE NOTE - some parts are currently away being painted , realistically its going to be another week before all items are wrapped and ready to go .
right ...
donor shell was Y reg mk 3 ford escort 1.6 auto ghia around 45 k on the clock before stripping , no previous damage , best possible shell to start with.. sierra was a twin cam ghia iirc donated by dojj to the project , stone fire mint again .
full sierra rwd conversion completed bk fabricator karl graham , work done to the best possible standard , no time or expense spared on any inch ,
sierra floor pan taken bk to bare metal all engine bay holes filled and smoothed all unessacary holes underneath filled and smoothed , wings added and fitted to mk 3 sills as per factory one of the best fitted floorpans in the country - looks 100% factory , custom floor to rear seat filler panels all swaged for strentgh , fully spotwelded and stich-seam welded where applicable
modified sierre bulkhead panel refitted profiled to mk 3 bulkhead,
modified front turrets to accommodate compbrake eccentric adj topmouts
custom 1 off removeable battery tray ,
custom 1 off tubular crossmember to allow 100mm cooler to be fitted
brand new escort front panel fitted
brand new x2 front wings fitted ( travelled to liverpool to exchange one as k wasnt happy with the fit !!)
both doors replaced with mint escort doors ,
o.e sills ,inners ect
rear chassis legs removed , blasted - etched - primed and refitted 3 inches further inboard ,
o.e rear tubs stretched 3 inch to accomodate wider larger rear wheels ,
all refitted as to factory standard ,
custom 1 off rear turrets with compbrake adj eccentric top mounts
custom 1 off fully swaged rear boot floor panel ,
custom wrc rear mount points fitted
all unessacary holes deleted ,
fully prepped body shell to concourse condition , fully seam sealerd to neatest poss finish , etched stonechipped were app ,new sound deadening 4 + coats of hi build primer - 3 coats paint -3 lacquer - more in places - underside painted to mirror finish , same for interior and engine bay , not a single inch unpainted ,
complete un molested s1 bodykit took back to o.e factory black plastic for best poss finish , built back up with primer ect- not orange peely like so many ,
modded de baged rs grille 5 bar ,
all kit refitted with new stainless bolts, ( not rivited ) and using custom tapered washers ,
exterior paintwork by gary " escosgaz " richardson , regarded as one of the best painters in the cossie scene and by far one of the best in the country .
all panel gaps , door gaps 100% mint
quality of entire paintjob is stunning , finished in jaguar/ range rover stornoway grey 2 k paint ,
no time - effort - expense was spared in the complete fabrication and painting of the car ,
i would estimate theres around 1600 man hours gone into the shell ,
items included with the shell ,
  • complete mk motorsport wrc style lateral link rear end , fully adjustable , cradle - link arms x 6 , 2 billet hubs , 2x 2wd bearing adapters steering arms , rosejoints, spacers ect ,
  • 4x compbrake eccentric top mounts
  • 2wd stock sierra engine bed
  • new adjustable tca's
  • as new comp struts
  • 2x ford granada 5 stud 2wd hubs , painted and rebuilt with bearings & new studs
  • 2x granny rear 5 stud flanges to suit fronts
  • modified steering colum with uj section ( needs painting )& bulkhead mount for mk 3
  • new 2wd non ps rack
  • stock pedal assembly
  • fully reconditioned sierra master cylinder / servo unit , new braided link line ,
  • modified and detailed wiper assembly motor
  • cosworth heater matrix
  • cos heater blower ( could do with better one )
  • brand new never fitted x2 esc headlights
  • brand new fitted ultra smoked rear lenses ( no longer available ) like hens teeth propper make the car
  • 2.5 litres of colour matched paint
also any odds and sods lying about the lockup for it , s2 dash , window motors , wiring ect ect ,
a full nut n bolt restoration diary of the build can be found here covering every aspect of the build
https://passionford.com/forum/restor...-breaking.html
its a prominent well known project , no corners cut and nothing hidden has been 4 years of my life , sadly its time to move on ,
imo arguably one of the best fabricated and converted mk 3 cossie shells in the country
genuine folk intrested can reach me on 07787354837 , please do not pm me , the project will be advertised on various sites and theres every possability your message could be missed ,
not looking for another project so no swaps for your cossie or rst ect
MAY consider a bike , 1000cc 2002 onwards ,depends what u got ....
price is Ł 8k ovno .
considering the time effort and money invested its a bargain ,
some pics of the shell
thanks for looking
beef
Old May 23, 2012 | 07:29 PM
Turbosimpsons's Avatar
Turbosimpsons
bargain of the year.
Old May 23, 2012 | 07:38 PM
dingla rs's Avatar
dingla rs
are the bits been painted by some one else lol
Old May 23, 2012 | 07:45 PM
-beefy-'s Avatar
-beefy-
ring ring answer ya fone lol !!
Old May 23, 2012 | 07:50 PM
-beefy-'s Avatar
-beefy-
ohh on a sub note ill give it a week or so before listing it on ebay ,
but as alot of you lads use various rs forums other than pf , id appriceated if you could link the add to your local forums ect ,
much appriceated ,
beef
Old May 23, 2012 | 11:19 PM
Gaaables's Avatar
Gaaables
I'm gonna buy a lot of lottery tickets this weekend. Looks awsome in grey, don't think I could sell something that had that much work gone into it. Glwts mate
Old May 24, 2012 | 10:53 AM
-beefy-'s Avatar
-beefy-
Got to go fella .
Beef
Old May 24, 2012 | 08:18 PM
bigpower's Avatar
bigpower
Awsome,
Always wanted a cossied MK3 but im not the guy to finish it , shame it wasnt a fully finished article as i would have been calling you ( obviously it wouldnt be Ł8000 LOL )
GLWTS bud
Old May 24, 2012 | 09:17 PM
Mr RS500's Avatar
Mr RS500
I was very seriously interested in this , I have bought somthing else now as you pissed about so long before advertising it
A great project for somone
Old May 24, 2012 | 10:57 PM
kaddyT4's Avatar
kaddyT4
awesome glwts and have a bump
Old May 24, 2012 | 10:59 PM
qad's Avatar
qad
love the colour and the paint work glwts
Old May 25, 2012 | 03:03 PM
-beefy-'s Avatar
-beefy-
Lol just trying to get the little things sorted lol
You could still have it the money u got , u got me number if u wanna pop thru paul
B
Old May 25, 2012 | 03:10 PM
E980VTJ's Avatar
E980VTJ
was this ever finished?
Old May 25, 2012 | 08:32 PM
nichol4s's Avatar
nichol4s
What in a week lol
Old May 25, 2012 | 08:35 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Nope! but it should have been.....
Old May 25, 2012 | 08:48 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Do it Paul, your the right man to do the shell justice
Old May 25, 2012 | 09:47 PM
WongRS's Avatar
WongRS
I'd love to build mine into this, not going to happen though, GLWTS mate.
Old May 26, 2012 | 09:15 AM
E980VTJ's Avatar
E980VTJ
Originally Posted by nichol4s
What in a week lol
were you following the original thread?lot of hard work and time has gone into this,whats changed your mind mate?fiancial,motivation seems a shame to throw the towel in after all the pissing about you went through
Old May 26, 2012 | 09:23 AM
COCHYN's Avatar
COCHYN
Crying shame
Old May 26, 2012 | 09:34 AM
nichol4s's Avatar
nichol4s
Yes but even if I wasn't the title kinda states it didn't get finished!
This shell is a credit to all involved and will make a really good example of what ford could have done, but as you say beef family comes first this is just a lump of steel you can get back one day but the early years of you little girl growing up will never
good luck bud
Old May 26, 2012 | 09:39 AM
E980VTJ's Avatar
E980VTJ
good luck bud
not really seen so many cars like this completed then broken down to parts then the shell sold sepratley!!
Old May 26, 2012 | 07:04 PM
-beefy-'s Avatar
-beefy-
No never finished .
B
Old May 26, 2012 | 09:09 PM
Lee Reynolds's Avatar
Lee Reynolds
Awesome Beefy and such a shame!
Old May 28, 2012 | 10:38 PM
Such a shame Beefy.You should of kept on with the project.
Old May 29, 2012 | 03:42 PM
MrJayware's Avatar
MrJayware
Looks very nice! Shame your not going to finish it but i wish you good luck with your sale
Old May 29, 2012 | 08:23 PM
-beefy-'s Avatar
-beefy-
Bump
Beef
Old May 31, 2012 | 09:44 PM
dingla rs's Avatar
dingla rs
some bits been painted for this
Old May 31, 2012 | 11:12 PM
-beefy-'s Avatar
-beefy-
Thanks Andy , got the last of the bits to pop up if u about the weekend .
Old Jun 7, 2012 | 08:49 PM
dingla rs's Avatar
dingla rs
^sorry beefy just seen this post i wasnt bout anyway ,its all rapped up ready to collected
Old Jun 8, 2012 | 09:38 AM
stevebuck's Avatar
stevebuck
If i was you Beef i'd just cover it up and forget about it for a few years unless you need the money.
Old Jun 8, 2012 | 11:52 AM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Its a shame Beef your'e selling it on before finishing it, but good luck with the sale anyway.
Old Jun 8, 2012 | 07:30 PM
s-line's Avatar
s-line
love this AAAAAA+++++++
Old Jun 9, 2012 | 12:00 PM
v man's Avatar
v man
Zee Germans are coming
buy it paddy
road trip
Old Jun 10, 2012 | 01:15 AM
tkracing's Avatar
tkracing
beautiful paint and welding and panel gaps m8 well done,,,,,, but whoever fitted that kit wants stabbed wi a rusty knife,
as said earlier throw a sheet over it for a couple o years, will only grow in appreciation.no plonker will buy it for 8k unfinished.
Old Jun 11, 2012 | 03:17 PM
jessie_rs's Avatar
jessie_rs
I have to agree pricewise whats wrong with the kit?
Old Jun 11, 2012 | 03:48 PM
cossie daz's Avatar
cossie daz
I think the shell is worth that .
The time and effort gone into is awesome
I would love to have this
Old Jun 11, 2012 | 08:32 PM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
Can't believe your selling this beefy! Needs must I suppose though.
What's the comment regarding the body kit all about!
Old Jun 12, 2012 | 11:47 AM
-beefy-'s Avatar
-beefy-
Thanks for the comments guys
Ric I've no idea what he's on about regards the kit ,
I know it's fitted right , unless he's making regards to us not riviting it ,
Old Jun 12, 2012 | 11:54 AM
-beefy-'s Avatar
-beefy-
When u look at base model rusty mk 1&2s are fetching 2-3k nowadays I think the price of the shell is quite reasonable considering there's over 2 grands worth of rear end included and a further 5-700 quids worth of parts in the sale
Deduct the above from the cost of the shell and if u think is still not worth it then ur the fucking plonker !!!
Old Jun 12, 2012 | 12:09 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Nothing constructive to say?
Keep quiet
