Supra diffs!!!
Old May 23, 2012 | 04:31 PM
peteh's Avatar
peteh
Default Supra diffs!!!
Anybody had experiance with these yet or is it to early days to pass judgment?
Just thinking about one of these instead of a gripper or bara jobbie cause they're meant to be 'bullet proof'...
any input would be great!
Old May 23, 2012 | 04:58 PM
3FRD's Avatar
3FRD
I'm in exactly the same boat, I know they can take the power but how well do they lock up in comparison to the likes of a gripper?
Old May 23, 2012 | 05:23 PM
scoooby slayer's Avatar
scoooby slayer
no thinking needed they are awesome, the end.
Old May 23, 2012 | 05:52 PM
glockenspiel lover's Avatar
glockenspiel lover
I would say it must be the best conversion money can buy for a cossie!!
The diff seems to be awesome in a supra and pretty unbreakable so should be a great conversion that im going to do too
Old May 23, 2012 | 05:55 PM
scoooby slayer
im only running the later small case housing with a carbonetics lsd in and it hasnt broken yet with over 800 hp on 295/30/19 r888s aswell, 1200 miles so far, early big case diff will be even stronger
Old May 23, 2012 | 06:33 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
the only disadvantage is that they weigh 45kg
so don't drop it on your foot lol
Old May 23, 2012 | 06:36 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
So about 15KG more than a standard rwd cossie diff then? Got to be worth the extra weight for the fit and forget factor
Old May 23, 2012 | 06:38 PM
v man's Avatar
v man
Zee Germans are coming
fair weight difference but as rich said faf
Old May 23, 2012 | 06:52 PM
peteh's Avatar
peteh
do you think youll add a mount at some point tony?
just mine for road use so dont wana be rattled to death, lol
Old May 23, 2012 | 07:51 PM
Turbosystems
Super Moderator
it is un sprung weight and will aid traction
Old May 23, 2012 | 08:11 PM
peteh's Avatar
peteh
...that a no then?
was hoping the 6 degree beam I ordered at the same time would help with traction, lol
Old May 23, 2012 | 09:12 PM
Turbosimpsons's Avatar
Turbosimpsons
do you mean a rubber mount?
Old May 23, 2012 | 09:20 PM
peteh's Avatar
peteh
yeah, or poly?
just you mentioned it before in a past post.
Old May 23, 2012 | 09:38 PM
3FRD's Avatar
3FRD
So how well do they lock up? Who's got one?
Old May 23, 2012 | 09:40 PM
Turbosystems
Super Moderator
we were discussing the insulated type mount today for road users
will be based on the 9 inch insulated diff mounts we did many years ago when we were fitting the big Ford 909 diffs to road cars
Old May 23, 2012 | 09:43 PM
Turbosimpsons
a rubber or polly mount could be made.. fraser is running a supra diff in his car, escozgaz has just had one installed in his car although i don't think he's run it yet. one will be going in the shonky saff very soon.
Old May 23, 2012 | 10:05 PM
pieterjan's Avatar
pieterjan
Also want to know this as this is the next thing to to on my cosworth.
Old May 23, 2012 | 10:39 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
thinkin about one aswell as i keep shittin diffs
Old May 24, 2012 | 12:48 AM
xr4x4rs's Avatar
xr4x4rs
what ratio are they? is there any close to the 3.6
Old May 24, 2012 | 01:10 AM
Sonic Boom's Avatar
Sonic Boom
I got this from the Supra Owners Club awhile ago:
Normally Aspirated - 4.30:1
2.5 Twin Turbos - 4.10:1
3L Turbos (87-88) - 3.90:1
3L Turbos (88-92) - 3.73:1
I keep searching for 3.9 one but they seem to be like rocking horse shit.
Rich
Old May 24, 2012 | 05:24 AM
fraser9764's Avatar
fraser9764
I can't fault the diff. I Dont even find it that harsh with the solid rear mount to be honest for normal road use. I'm using poly beam mounts and a 6 degree rear beam.
Old May 24, 2012 | 05:41 AM
vinge87's Avatar
vinge87
anyone have pictures of a setup? what shafts to use?
Old May 24, 2012 | 06:21 AM
pieterjan's Avatar
pieterjan
Tony at turbosystems does a kit that fit straigt into an original cosworth beam and whit standart shafts.
Here is a link whit pictuers off the diff. I hope i can get a discount now for all this advertisement lol!
https://passionford.com/forum/restor...-figure-4.html
Old May 24, 2012 | 06:51 AM
vinge87's Avatar
vinge87
Talking
Thanx mate
Old May 24, 2012 | 07:03 AM
Turbosystems
Super Moderator
the conversion bolts straight in to a 2wd beam and uses the standard 2wd drive shafts and std prop
How clever are we
This conversion is a combined effort between Myself and captain grumpy John (Jack Dee)
Old May 24, 2012 | 07:43 AM
joffy's Avatar
joffy
SLOW LEARNER
whats the score with speedo calibration, how far out is it? is there any mod you can make?
Old May 24, 2012 | 08:12 AM
Mike1's Avatar
Mike1
Interesting development certainly and if there's a roadgoing mount ( like for the 9" Ford one ) it would be great.
So, in summary, the 3.73 is closest to the rwd Ford one. How much are the gear ratios affected - anyone know ( using standard rev limit ) and how much higher is top gear revs at, say, 70mph?
Old May 24, 2012 | 08:37 AM
Turbosystems
Super Moderator
The 3.64 standard ford ratio is too high we used to alter these to 3.9
much more drivable unless of coarse your aim is to beat rods top speed lol
Old May 24, 2012 | 08:38 AM
Turbosystems
Super Moderator
The standard speedo is miles out any way so can't be any worse really lol
speedy cables can calibrate your std speedo any way
and it's hardly a big worry fitting a 3.7 diff as most people have messed the speedo up any way with 17's 18's and 19 inch wheels
The cosworth is still running a 1950's cable speedo ffs
Old May 24, 2012 | 09:33 AM
Mike1's Avatar
Mike1
I hear what you're saying. I'm still on standard 205/50x15s and standard diff ratio but my speedo isn't too far out according to different GPS apps/devices.
How much is it to source and change a 3.9 7.5" ratio ( 2wd car ) for a standard Cosworth diff as an aside?
Old May 24, 2012 | 09:34 AM
vinge87's Avatar
vinge87
How clever are we
Then it will go strait in a MK-motorsport rear wrc craddle to???? how much for a diff 3.9 ratio??
Old May 24, 2012 | 09:58 AM
DaveCrack's Avatar
DaveCrack
Looks like a clever bit of kit!!! How much is the conversion incl. adaptor and flanges and also how much is the 6 deg beam?
Old May 24, 2012 | 10:00 AM
750hp escos's Avatar
750hp escos
The conversion is a Ł1000 as my mate wants one and has asked but i dont know how much the 6 degree beam is?
What ratio is the one you supply tony and does it come all pretty?
cheers danny
Old May 24, 2012 | 11:03 AM
Turbosystems
Super Moderator
it is all shite and briney all adaptors are electroplated in gold
all other fittings are powder coated black
the diffs are either black or silver
ratios currently available are 3.7 at 1k
we can do from 3.6 to 4.3 but these are extra as we have to use a new crown wheel and pinion which is on top of the 1k
personally I think the 3.7 at 1k is a bargain and fine for most peoples needs
The 6 degree double adjustable rose jointed beams are 1K exchange another serious bargain
Old May 24, 2012 | 11:06 AM
DAN-Saff's Avatar
DAN-Saff
Do they come with a viscous diff or torsen diff?
Old May 24, 2012 | 11:08 AM
750hp escos
Yea 3.7 will work for almost any app really and seeing as it all comes lovely and clean etc is a bargain and a no brainer compared to any thing else on the market!!!
We will be sourcing one from you very soon..
cheers danny
Old May 24, 2012 | 11:11 AM
Turbosystems
Super Moderator
will have to check which ones we currently have available
Old May 24, 2012 | 11:56 AM
750hp escos
yes please as just spoke to j and he wants one asap mate
Old May 24, 2012 | 12:00 PM
Turbosystems
Super Moderator
they are likely to be Torque Sensing Traction torsen differential units
Old May 24, 2012 | 12:24 PM
xr4x4rs's Avatar
xr4x4rs
3.7 wont work for 4wd though
