Cracked grill
Old May 23, 2012 | 10:46 AM
david 100's Avatar
david 100
Default Cracked grill
Had the 3 door out yesterday and was doing about 60 when a pheasent flew out and hit the front of my car cracking the grill just abover the Ford badge, can this be repaired and how please.
Old May 23, 2012 | 11:52 AM
v man's Avatar
v man
Zee Germans are coming
id leave the pheasent hanging out the grill for as long as poss
Old May 23, 2012 | 11:57 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Post a pic up mate, does not sound too bad though a decent body repair shop should be able to repair it perfectly.
Old May 23, 2012 | 12:57 PM
david 100's Avatar
david 100
Cant mate, i had it for tea,
Going to have a go at it myself and see how it goes.
Old May 23, 2012 | 03:09 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Reinforce it from behind with either fibreglass matting and resin or some would use fibreglass filler. The sand down the front pael and lightly fill it. High build primer and flat off then paint it in whatever colour your car is. Work out cheaper this way then buying a second hand one i'd say
Old May 23, 2012 | 03:38 PM
david 100's Avatar
david 100
Thanks for that, i'll give that a go.
Old May 23, 2012 | 03:40 PM
Make sure you bond it front and back or it will crack again,make a grove front and back where the crack is ,then fill this with bond
mk1turboestate
Dec 2, 2015 08:31 PM
muzzman1
Sep 30, 2015 08:59 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Bailes1992
Sep 19, 2015 02:17 PM
Adam Graham
Sep 6, 2015 06:04 AM
