Ford KA Discuss your Ford KA here!
ford ka colant/thermostat problem? help please
Old May 21, 2012 | 07:52 PM
st220kyle's Avatar
st220kyle
Default ford ka colant/thermostat problem? help please
2002 ka problem that seems to start loosing water once warmed up, but by the time its loosing water it is actually steaming, wondered if a faulty thermstat could be at fault, it only seems to do it when water pressure has built up quite high
any ideas?
Old May 21, 2012 | 08:07 PM
matts1's Avatar
matts1
Not sure if this will be the case,but we had a KA that lost water, but no obvious leaks or head failure.
Turned out to be a common issues with the cap on the expansion tank, the rubber seal in it perishes or gets twisted and doesnt create a seal and so the water evaporated.
I refitted the seal flat again and it solved it. I did find out though that the fan doesnt kick in until the water reaches 105 degrees, which seemed odd, but when I let it run longer, it did kick in.
Was shocked out how much water evaporated and how such a small cheap fix sorted it.
Worth a check.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
nick8saff
Aug 16, 2015 05:35 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
