sapphire rad change
Old May 19, 2012 | 10:28 PM
johnnycortina's Avatar
johnnycortina
Default sapphire rad change
Hi - I just put a new rad in my 2wd sapphire. Refilled and had it running again - but I notice a lot of air bubbles coming back into the header tank from the small return line from the turbo. Do I need to bleed system somewhere, and is there a recommended method or place to do this. Thanks.
Old May 19, 2012 | 10:53 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Just did mine,all i did was leave header tank cap off while engine ran up to point of fans coming on,all air bubbles came out while i was squeezing the water pipes.When engine was cold i topped it up to max level on tank.
Old May 19, 2012 | 11:52 PM
langer's Avatar
langer
Put your heater on an make sure your getting hot air coming through too.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
liamT74
Sep 23, 2015 10:24 PM
tib2220
Sep 14, 2015 12:33 PM
marky_g
Sep 12, 2015 04:26 PM
