People who've run a seperate fuel pump loom!
Old May 17, 2012 | 08:55 AM
rog's Avatar
rog
Default People who've run a seperate fuel pump loom!
Good morning my esteemed pf colleagues!
When you ran the loom in your car, how/where did you take the loom from inside the boot, to outside the car to connect it to the fuel pump?
Before I go butchering the car and tyriying to stick in grommets etc unnecessarily, I wanted to know the easiest and cleanest way to run the new feed, also any comments on where you earthed the new fuel pump loom would also be helpful. My car looks nice and not thrown together, so I want to contiue this!
Also where/how have you mounted the relay?
Old May 17, 2012 | 09:56 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
mine gos through a grommet in the spare wheel well
Old May 17, 2012 | 10:11 AM
rog's Avatar
rog
I don't have a grommet, I checked last night.
Old May 17, 2012 | 10:12 AM
ajamesc's Avatar
ajamesc
mine dose lol maybe it was fitted by m.a.d when the loom was done i guess
Old May 17, 2012 | 10:15 AM
Sonic Boom's Avatar
Sonic Boom
On my 3 Door there is two small rubber gromets to the right of the wheel well next to the back panel on the flat section of the boot floor.
I just poked the wires through the one on the left no drilling required.
Rich
Old May 17, 2012 | 10:16 AM
rog's Avatar
rog
Thanks,
I have the metal piece at the back that holds on the fuel pump cradle, then at the other end I have two metal inserts that I can take out, i presume if I get the right size grommet I can pass it through there but it's knowing what to use. Might just have a rake around the scrap yard and see if I can scout anything that'll fit.
Old May 17, 2012 | 10:48 AM
tosh's Avatar
tosh
Same as Sonic boom but mine is a sapph, it's where th old loom goes through to the pump cradle
Old May 17, 2012 | 01:18 PM
Toe Knee's Avatar
Toe Knee
I just went through the original grommet for the original wiring. I routed mine through the grommet under the batt tray and along the passenger side of the car
Old May 17, 2012 | 01:37 PM
gibbo frst's Avatar
gibbo frst
mines got the grommet too.. and i screwed the relay to the fuel cut switch thing in the wheel well... dont know how the aftermarket looms work as i made my own.. from battery thru fuse then to the new relay. used original fuel pump loom to trigger the relay.. has worked fine for years.
Old May 17, 2012 | 07:30 PM
WongRS's Avatar
WongRS
Mine went through a frigging big hole i drilled to get wires through behind the battery! lol.
Old May 17, 2012 | 07:37 PM
Mibe goes through the original gromit in the spare wheel well.
Old May 17, 2012 | 08:14 PM
tosh's Avatar
tosh
Just found some pics and it jogged the memory,
From the battery then it goes through the grommet on the bulk head.
Then under the carpet along the sill to the boot area
Then it goes through the original grommet which is on the flat part of the boot floor near to were the jack is.
Then you loop it underneath and up through the original grommet in the spare wheel well next to the inertia switch, connect it all up to the new relay and then run the feed back out the same grommet to the pump,
all a bit long winded I know but it might help someone
Old May 18, 2012 | 07:07 AM
WongRS's Avatar
WongRS
I miss read it, yeah, through the grommet in the boot floor.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
