Ford Non RS / XR / ST parts for sale. All Ford Car parts in here. (Non RS / XR / ST ONLY please) Starting a topic requires you to have purchased a gold membership.
Breaking mk6 Amparo Blue Escort - zetec turbo parts
Old May 15, 2012 | 08:35 PM
roddsescort's Avatar
roddsescort
Default Breaking mk6 Amparo Blue Escort - zetec turbo parts
Right then boys and girls, the time has come.. ive come to the end of the road with this car..
So ill be breaking the whole car..
As it stands...
At the moment it has no interior at all.. but all body panels etc
So Ill start with the zetec turbo parts..
2.0 ltr mondeo silvertop block - about 90k, no damage to the bores. Has had 2 holes tapped in for breather and oil return from turbo.
It is currently in bits, but it will come complete with original crank, pistons and rods with used a.r.p big end bolts, oil pick up and 1.6 escort sump, i can supply used oil pump, water pump, crank pully and fly wheel.
£80? collection only.. or i can bring to santa pod for classic ford
Standard cylinder head which was paired with the above, with standard 2ltr cams
£40 on its own or £20 if bought with the block.. again collection only or can bring to santa pod for classic ford
Area six ported and polished silvertop zetec E cylinder head - not been on the car since re-build - has area 6 zetec turbo spec valve springs in with new valve stem seals
£350 collected - can take to santa pod for classic ford
Garrett T3 turbo with -31 actuator and 360 degree bearing - freshly refurbed by midland turbo's - complete with new gaskets and escort rs turbo manifold - like new!
£350 - collection only or can be taken to classic ford
escort rs turbo exhaust manifold - £30 posted £25 collected
Zetec E cam cover 'DOHC' logo powder coated black - good condition - £30 posted £25 collected
Ford racing Bonnet raisers powder coated black - £22.50 posted £20 collected
Escort rs turbo braided turbo feed £22.50 posted £20 collected
Collins boost gauge 52mm - £35 posted
Auto guages - all brand new in the boxes - come with all wiring and sensors needed £28 posted each
Available - Boost - Coolant temp - Oil temp - Oil pressure
Bailey dump valve - purple - with sfs hose kit in ornage £50 posted £45 collected
Efi inlet sfs silocone pipe for inlet to crossover pipe - brand new in orange jubilee clips
£8 posted
Roose coolant hose kit in silver for mk6 escort - top rad has been cut to allow temp sensor to be fitted - included in the sale £100
Coolant swirl pot, not sure what its off - with a few samco hoses - £22 posted
Guage surround - 3 x 52mm holes with rs logo in corner £15 posted
Bosch/cosworth side-fed injectors from the indy-car programme - flow enough for 320bhp at 4.5 bar fuel pressure on a zetec.. bought from Stu @ grove garage so he will know all about these if you need any more info..
Brand new apart from calibration testing.
£180 posted - £175 collected
Universal intercooler - was off a fiesta rs turbo - about 50/60mm core £50 collected
Escort mk6 Spax rsx coilovers fully adjustable - used but in good working condition with all spanners and adjusters
£250 posted £235 collected
300mm front brake setup - everything needed including calipers, carriers, pads discs, correct bolts and mk1 hoses which havent seen a road mile. Discs and pads are practically brand new.
£120 posted £100 collected
ST170 rear discs set-up calipers, hoses, handbrake cables, discs and pads have seen about 200 road miles, so practically brand new - bearings all ok
£165 Posted £150 collected
Escort front lower strut brace - Was brand new 200 miles ago made by Danzetec as some of you may know - £45 posted - £40 collect
Front gti bumper in amparo blue - good condition - few scratches on n/s front but not too obvious unless pointed out £50 collected
Rear gti bumper in amparo blue - good condition - few light scratches £50 collected
Gti side skirts in amparo blue - have scratches on underside but not visable when on the car - come with 3 jacking point covers - missing n/s front £50
Ill do the whole body kit for £110 if all 3 are bought together!
Rs accessory Front grille from germany - £55 posted £50 collected
Escort boss kit - £25 posted £20 collected
After market leather steering wheel with OMP horn button - £50 posted £45 collected
Fiesta silver/black mp3 alloys - 16's - been painted black, but starting to peel all over so would benifit from refurb - all straight £50 collected
Ford racing escort clock £7.50 posted
Dash surround £10 collected
lights/wiper controls £8 posted
smoked side repeaters - £10 posted
1.8 gti inlet manifold with 2ltr throttle body and 2ltr injectors - £20 collected
Brand new gates zetec timing belt - £15 posted
Zetec turbo block breather blanking plate £8 posted
Standard escort fan £10 collected
Random fans - not sure what there off - £10 each
Fan switches - both have led's when switched on.. £5.00 posted each
Escort rs turbo rear braided brake hoses - brand new £35 delievered
Fiesta mk3.5 subframes - good for fitting aftermarket seats/bucket seats - come with top hats
escort ib5 gearbox from a 1.6 - £25 collected
There are many many many other bits such as..
Starter motor
Alternator
Pas pump
Pas rack
Brand new drop links
All doors - no rust - no inner door cards or speakers - with colour coded handles
All Glass available
Door and boot seals
digital cluster - white dials £20 - around 40k milage
Full wiring loom
Heather box
Mint dash
Steering column
rear beam
front subframes
Pretty much everything on the car..
So if theres anything you need - just let me know
The whole shell is available if anyone wants it.. its got slight corrosion on sills and on o/s rear arch - but apart from that its mint as you can tell from the pictures.. shame to have to scrap it realy!
£300 With all the doors/glass and bonnet
Any other questiuons dont hesitate to ask!
Make me offers, as i need it all gone.. if it doesnt sell, it will be scrapped!
You can reach me on my mobile any time in the day - 07858322822
I WILL be attending classic ford at santa pod so can bring most bits along..
Pictures will follow tomorrow..
Last edited by roddsescort; May 17, 2012 at 09:33 PM. Reason: updated with pictures and extra items
Old May 15, 2012 | 08:48 PM
superbikerider1's Avatar
superbikerider1
Text sent regarding oil pump etc
Kev
Old May 15, 2012 | 09:07 PM
roddsescort
oil pump, crank pulley and toothed pulley sold
Old May 19, 2012 | 12:35 PM
superbikerider1
Parts arrived thanks! Quick delivery! Do you have the gearbox sandwich plate? between block and box? Is it front mount starter? If so I'd ave that too!
Kev
Old May 19, 2012 | 07:42 PM
roddsescort
no worries i do, but its a rear start on mine!
Old Jul 29, 2012 | 12:55 PM
Churtz's Avatar
Churtz
Hi.
Do you have a zetec to rs turbo exhaust manifold adapter by any chance?? If so how much?
Matt
Old Aug 26, 2012 | 09:02 PM
BigRay91's Avatar
BigRay91
hi, were was collection from? and did the bumper sell? thanks
Billy_RS
16
Oct 11, 2025 09:41 PM
Churtz
15
Aug 13, 2015 06:40 PM
turbobill
Aug 9, 2015 05:21 PM
Cameron
14
Aug 9, 2015 06:28 AM
turbobill
Aug 1, 2015 08:55 PM
