lambda boss
Old May 15, 2012 | 03:23 PM
martinmilne's Avatar
martinmilne
Default lambda boss
Pics of where people have mounted them in exhaust pls
Old May 15, 2012 | 04:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No pic but it's just after the sump and before the flexi.
Old May 15, 2012 | 05:57 PM
martinmilne
This is where im struggling as rob said same thing to me but my flexi joining bit seems to be inline with back of sump
Old May 15, 2012 | 06:20 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It is close, mines probably about 2-3 inches back from the sump plug (sensor points at drivers wing parallel with the floor).
Old May 15, 2012 | 06:37 PM
martinmilne
mine would be directly under sump inless i mounted it before sump as it goes down to go under the sump as ideally i need it before a flange joining section ?? where would be best so yours is horozontal from pipe pointing towards wing karlos
just want to make sure mine is mounted right
Old May 15, 2012 | 07:08 PM
studabear's Avatar
studabear
Old May 15, 2012 | 07:30 PM
martinmilne
great pic thanks but my downpipe is a bit more of a gentle curve going to sump so flat bit starts just at bottom of sump bloody crap exhaust lol
Old May 15, 2012 | 07:48 PM
little bram's Avatar
little bram
sorry for bad pic
Old May 15, 2012 | 08:38 PM
martinmilne
very near turbo i thiught this was bas idea because of heat ?
Old May 15, 2012 | 08:58 PM
little bram
If you look at most cosworths they are all put just behind the turbo and ive had no problem with mine.
Old May 15, 2012 | 10:14 PM
Rob_DOHC's Avatar
Rob_DOHC
Hey Bram, hows the car going mate? you won't have a problem with readings etc, but your sensor will have a shorter life.
Martin, you can literally mount the sensor where ever you like, mine is before the sump, pointing at around 11 o'clock IIRC, I may be going to the garage this weekend so if I do I'll grap a few snaps for you
Old May 16, 2012 | 06:27 AM
martinmilne
Ok rob cheers was bit worried where to mount but got a few places I can do it if its not to much of a problem being near turbo then can get my ecu fitted
Oranoco
41
Feb 11, 2016 01:28 PM
rsguy
44
Sep 29, 2015 03:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Si B
Sep 12, 2015 06:49 AM
RsS2daz
Aug 14, 2015 05:26 AM
