Anyone help me find out what i need for this ?
Old May 13, 2012 | 09:25 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Default Anyone help me find out what i need for this ?
I am in the process of reassembling the car and have mislaid something.
The gearbox is an IB5 andt fits in the gearbox and comprises a lenght of metal about 3 inches long and there is also a spring.
I am trying to identify what it is and if someone has a spare sitting around they dont need.
It fits in this hole where there is a blank cover - does it actually do anything as i have a spare gearbox and there is not one in that gearbox
Hopefully someone can help
Pics of the place where the item fits ..........
Old May 14, 2012 | 09:30 AM
s2turbsZVH's Avatar
s2turbsZVH
Anyone ???
Old May 14, 2012 | 10:40 AM
Rob_DOHC's Avatar
Rob_DOHC
reverse light switch.... I removed mine and fitted a blanking cover like yours....
should be located on the bottom of thre gearbox towards the front of the car.
Rob
Old May 14, 2012 | 10:42 AM
Rob_DOHC's Avatar
Rob_DOHC
http://www.ebay.co.uk/itm/Genuine-Fo...item4a9ee5f77b
Old May 14, 2012 | 06:19 PM
s2turbsZVH's Avatar
s2turbsZVH
Rob
Cheers - obviously i have the normal Series 2 reverse light switch fitted (see pic below) so essentially what you are saying is that i dont really need anything there then and its fine just being blanked off ??
Old May 14, 2012 | 07:03 PM
Rob_DOHC's Avatar
Rob_DOHC
Didn't even know the standard switch fitted, have you replaced the detent next to the 'blanked hole' with it?
But yes, just blank it. Mine has been blanked for quite some time.
Rob,
Old May 14, 2012 | 09:38 PM
s2turbsZVH's Avatar
s2turbsZVH
Rob,
Well after a lot of messing about it apperas it was fitted where it should have been all along.
The bit i had thought i had mislaid was this
As you can see from this picture - its already fitted - doh !!
As for the reverse switch its fitted here so all in all problem solved - thanks for you help though really appreciated.
Old May 14, 2012 | 11:37 PM
Rob_DOHC's Avatar
Rob_DOHC
Lol, sorry mate... I really thought you were talking about the part that fits under the blanking cover
Cheers for the reverse light switch though, i'll see if mine has a suitable hole.
Rob,
Old May 15, 2012 | 07:16 AM
s2turbsZVH's Avatar
s2turbsZVH
Rob,
I was - well i thought i was until i discovered that i was completely wrong
Old May 15, 2012 | 10:15 PM
Rob_DOHC's Avatar
Rob_DOHC
Ahhh cool, at least it wasn't lost! imagine describing that to your local ford parts monkey lol
mk3ste
Oct 17, 2021 10:09 AM
boeb
Jan 9, 2020 05:11 AM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
